I was wondering, if cedar siding shows clear signs of cupping, is this something that should be stated in the home inspection report?
| Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
is the siding cedar planks or shakes? Got any pictures?
[QUOTE=Unregistered;657261]I was wondering, if cedar siding shows clear signs of cupping, is this something that should be stated in the home inspection report?[/QUOTE]
If it is 6" to 8-9" exposure cedar clapboard, yes, it should be mentioned. The cause would be nailing more than the recommended 1" maximum above the bottom of the board. Did a litigation about 7 years ago on a good local prefinished product, Cape Cod Siding. the manufacturer specified nailing 1" inch up fromthe bottom of the clapboard; I could barely find a nail at 1" up from the bottom most were 2+" with some greater than 2.5"!! The manufacturer, siding vendor and builder all shared the cost ($18,000+) of replacing the improperly installed product......it had been installed by a subtrade who just disappeared!! |
Tongue and grove planks.
I have pic's, but primary just wondering if Cupping is something that would be normally stated in a report at this point. Where would you like the pic's sent to if you would like to review them? |
Tongue and grove plank.
I have picks, where would you like me to send them? However, at this point I was just wondering if cupping is normally stated in inspection reports? |
