| California Inspectors This is a place for California InterNACHI inspectors to discuss California inspection topics. |
gfitzgerald is a non-member guest and is in no way affiliated with InterNACHI or its members.
I had an agent tell me yesterday that the City of Burbank and Long Beach did not require them ?? Since it is Sat. and the B&S is closed I was wondering of anyone knows this is true for sure. If not do you have any code reference to share. Thanks
| Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Gary, you can make any recommendation that you want...for enhanced safety works well.
New Year and new requirements always take place - check with the City of Long beach and Burbank planning, building and safety departments. I always add a disclaimer in my reports -
In an earthquake, the shaking of a home or apartment can cause damage to gas piping and appliances. This damage can result in releases of natural gas that can lead to fires or even explosions. Structural weaknesses, the absence of appliance anchors, seismic activity, and a lack of flexible pipe connections can all contribute to a greater possibility of natural gas leaks. This problem is so prevalent that natural gas contributes to one of every four fires after an earthquake. A primary concern when dealing with natural gas leaks and ensuing fires is the protection of property, rather than personal safety, because most homes have several potential exits for escape from a fire. If GSOV not installed - Recommend the installation of a approved Gas Shut Off Valve by a state licensed plumber or contact the local gas utiltiy company for guidance. |
Thank You for the reply's .. I always note the presents or not of the GSOV I just do not understand how some City's within the State and County can chose to adopt this life saving safety measure or not.
The EQSOV is only required by the "City of Los Angeles." Basically, it includes any city under the authority of the LADWP. However, incorporated cities within LA city limits have the right to opt out of this requirement. In addition, unincorporated LA County has no such mandate. Also, there is no provision in the State Code requiring EQSOV's. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
do you have a pic?
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
A lot of the installed seismic valves I see are wrong...
Mark, I attached a pic of a common valve in CA. For others in CA or if you inspect where SoCal Gas is, pay heed to the image attached. You'll find a lot of our valves lack the required wall brace as well as being in the Gas Co's "facilities". A lot of newer construction has these valves incorrectly in the vertical upright. Please feel free to use the images. |
Thanks Tim,
Not an issue in Brossard Quebec, but they are good pictures! |
thank you
dbostick is a non-member guest and is in no way affiliated with InterNACHI or its members.
Tim - please elaborate on the wall brace requirement. And do you have anything in writing that states that a vertical orientation for a GSOV is prohibited?
Thanks. Darin Redding, CPI Housecall Property Inspections san diego home inspection rental inspection | warranty inspection Facebook Like darin@sandiegohomeinspect.com 619-663-8740 home inspector in San Diego, Carlsbad, Poway, La Mesa, El Cajon, Chula Vista. |
Vertical orientation is OK, as long as you're outside of Gas Co's equip. The valves are sold in horizontal, vertical Up & Down flow.
The illustration I provided is from SoCal Gas's website for acceptable and prohibited locations. The wall brace requirement is a manu one, it's on the literature with the valves that I've bought/installed etc. The instructions are specifically at http://www.littlefirefighter.com/pdf...on20060124.pdf noted in section 10 for requirements. You can find more literature at http://www.littlefirefighter.com/instruct.htm# Hope I helped. |
Thanks Tim.
| Gas shut off valve | Laura Line | Plumbing Inspections | 7 | 1/26/10 1:04 PM |
