Go Back   InterNACHI Inspection Forum > Local Inspection Issues > California Inspectors
California Inspectors This is a place for California InterNACHI inspectors to discuss California inspection topics.
Old 10/3/11, 8:53 PM
Brian K. Smith's Avatar
Brian K. Smith Brian K. Smith is offline
Send a message via AIM to bsmith2
Default Fire door???
Anyone know what the year was, when the door between a garage and interior (kitchen ect) had to be a one hour fire rated door?
Need a home inspection in Wyoming? Check out InterNACHI's listing of Wyoming certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/3/11, 9:47 PM
Christopher Currins's Avatar
Default Re: Fire door???
No, why does it matter?
Christopher Currins
Certified, Licensed
Old 10/3/11, 10:08 PM
It matters to me...
Old 10/4/11, 12:15 AM
Paul Pendley Paul Pendley is offline
I have 2003 IRC 309.1, and 1997 UBC 302.4x, 20 min rated self closing. Hope this helps
Paul Pendley
Premier Property Inspections
866-458-8516
Old 10/4/11, 1:53 PM
Jeffrey R. Pope's Avatar
It's required to be a 20 minute door. The code has been in effect as early as the fifties, but I believe it dates back even earlier than that.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/4/11, 6:01 PM
thanks for the info....one hour wall and a 20 min door...hummm...ive been always calling the doors out at one hour needed...
Old 10/4/11, 6:21 PM
This along with related subjects may help some along the way;
There is a common assumption that a wall with a certain fire rating will require a door with an equal rating. While the door will generally need to be rated it oftentimes requires a lower rating. These are the numbers from the 2006 International Building Code.
First, exterior walls always allow reduced ratings in doors. Both 3 hour walls and 2 hour walls require a 90 minute door. A 1 hour exterior wall requires a 45 minute door.
Where you have a fire barrier with a 1 hour rating at a shaft, exit enclosure or exit passageway you will need a 1 hour door. For other fire barriers it is reduced to a 45 minute door.
Where you have a fire barrier with required rating over 1 hour the need for reduction varies. Both a 4 hour wall and a 3 hour wall require a 3 hour door. Both a 2 hour wall and a 90 minute wall require a 90 minute door. In the 3 hour wall they will allow you to use a pair of 90 minute doors, but only in that once instance.
A 1 hour smoke barrier requires a 20 minute door.
Fire partitions that are corridor walls allow reductions. For either a 1 hour wall or a 30 minute wall you'll need a 20 minute door. With any other fire partitions a 1 hour wall requires a 45 minute door and a 30 minute wall needs a 20 minute door.
In summary, it is actually a very confusing chart, so feel free to check back when you are putting together your door schedule.
http://evstudio.info/fire-door-prote...wall-assembly/
Old 10/4/11, 8:49 PM
Thank you for the good info Marcel
Builders and Real Estate Agents Conspire to Kill Fire Fighters jbushart General Inspection Discussion 146 11/9/10 4:40 PM
Garage door inspection procedure bgromicko General Inspection Discussion 5 8/7/09 12:47 PM
Fire Codes ccrooker Canadian Inspectors 0 11/14/08 12:13 AM
