Go Back   InterNACHI Message Board > Geographically Specific Forums > California Inspectors
California Inspectors This is a place for CalNACHI members and California InterNACHI members to discuss California inspection topics.
Old 4/24/08, 2:42 PM
Joe Mathieu Joe Mathieu is offline
Default Moisture Meter
I am new to this business and I have most of the tools I need for HI. However, I was wondering whether or not I should purchase a moisture meter and if anyone could recommend any that seems to work the best in most situations. I would appreciate any advice or info on this topic. --Joe M.
Old 4/24/08, 3:08 PM
Douglas Cossar Douglas Cossar is offline
Default Re: Moisture Meter
Protimeter mini Got mine at Pro Lab
Enjoy
Doug Cossar CMI, PHPI
Accurate Home Inspection
Services Inc.
Whitby Ontario
www.accuratehomeinspections.ca
05021384
Old 4/24/08, 4:36 PM
James H. Bushart's Avatar
Delmhorst BD-2100, for me.
Old 4/24/08, 4:45 PM
Linas I. Dapkus's Avatar
Linas I. Dapkus Linas I. Dapkus is offline
Ditto. I got the EIFS probes. Also use a Protimeter non-invasive. And a BCam
Old 6/10/08, 1:17 AM
If you go for the Protimeter Surveymaster, you'll have both a pin-type meter and search meter in one. I have one and use both features on many inspections. It's lasted 5 years now with no problems.
Search meters don't give accurate levels of moisture but will find moisture behind tiles and under vinyl.
Pin type meters will give a more accurate reading of actual moisture content, depending on the brand. Some come with calibration tables and are fairly accurate in variety of materials and wood species.
Which you buy depends on what type of homes you'll be inspecting. We're not often required to know accurate moisture levels, so setting a baseline in materials you know have normal moisture levels will allow you to make comparisons with similar material in different areas and identify areas with significantly higher moisture levels.
If I had to choose between a search meter and a pin meter I'd choose the search type. People seem to really like the Tramex, but I think inspectors tend to like what they're used to unless it's obviously bad. I think the Wagner is less money.
The Tramex will actually record readings and display them later, which might be a good feature if you were doing a methodized search over a large, uniform area. Most of what we do only requires checking small areas, at least for most of us.
Having a moisture meter is crucial to providing quality inspections.
EXPERT WITNESS
Director of Green Building
Director for International Development
(303) 717-8940
(303) 258-8289
Old 6/10/08, 1:36 AM
jkogel jkogel is offline
Yes, I sometimes use my Surveymaster meter to demonstrate an absence of moisture, where repairs were carried out but the buyer is doubtful. On a finished surface, pinless is the only way to go.
John Kogel
www.allsafehome.ca
Old 6/10/08, 10:34 AM
dplummer dplummer is offline
Please Note: dplummer is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have a couple different types. My favorite is the GE Protimeter Plus. It has penetrating & non penetrating , Relative Humidity,Deep wall probe, surface temp, it can be used for detecting Hygroscopic Salts or in Condensator mode for confirming surface condensation.All readings can be saved & down loaded to a PC. Comes all in one case. About $1,100.00 Canadian.
Doug
Old 6/11/08, 1:24 AM
That brings up a point. Just because it's got pins doesn't mean you have to push them. Pin meters can even be used to confirm moisture in concrete. How deep will they read compared to meters with the search feature? I don't know. I'm going to contact Chris Ranwell at protimeter and see if I can find out.
EXPERT WITNESS
(303) 717-8940
(303) 258-8289
Old 6/11/08, 10:39 AM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
Enjoy
Same here.
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Old 6/11/08, 10:43 AM
Here's a couple of links: http://www.professionalequipment.com...oisture-meter/
http://www.toolexperts.com/product.p...2dcff3f384826a
Robert Newland
Tyrone, GA 30290
NACHI05101290
Old 10/23/08, 5:02 PM
Cassandra Moore Cassandra Moore is offline
Please Note: Cassandra Moore is a non-member guest and is in no way affiliated with InterNACHI or its members.
In regards to moisture meters being used in concrete, I would suggest following the links below for some very helpful information.
http://en.wikipedia.org/wiki/Concrete_moisture_meters
https://www.wwwagner.com/permission.php
At the second link you can watch a webinar that shows that moisture meters can be a very dangerous way to measure moisture in concrete. According to this information, most moisture meters can only read what’s going on within the first inch of the concrete slab. This lack of proper information can lead to flooring failures.
Old 10/23/08, 6:49 PM
Keith Swift, PhD. Keith Swift, PhD. is offline
Same as Kenton: Protimeter.
InterNACHI Vice President, InterNACHI Editor-in-Chief, co-founder CalNACHI
Old 10/24/08, 12:39 PM
Vern Mitchinson's Avatar
Vern Mitchinson Vern Mitchinson is offline
I have been using the CT808 from http://www.electrophysics.on.ca/e_index.htm and it comes with calibration directions and plate and directions for setting on different materials. Iwould purchase the CT828 at http://www.electrophysics.on.ca/e_index.htm
I use it on every inspection where a basement exists and that is every house.
Vern Mitchinson CET CMI
Past President
International Association of Certified Home Inspectors. Alberta
Old 10/26/08, 2:29 AM
Justin Watts Justin Watts is offline
I wonder what percentage of home inspectors are using thermal cams? And if they are using them, are they charging for their use???????????? I know this is another topic, but I think they are far more superior than any moisture meter.
Old 11/1/08, 12:16 PM
whandley's Avatar
whandley whandley is offline
Please Note: whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
I don't think to many inspectors here in California are using them. I don't even see the environmental consultants using them on a regular basis...
In 23 years of inspection service, I've never had a client ask me about thermal imaging services... Not once!
Preventing Moisture related Problems mcyr Ancillary Services & Additional Topics 1 12/19/07 9:30 AM
Moisture in slabs mcyr Structural 7 8/20/07 8:33 PM
bbbb mcyr Structural 1 8/19/07 11:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 8:53 PM
Copyright © International Association of Certified Home Inspectors, Inc. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
