| California Inspectors This is a place for California InterNACHI inspectors to discuss California inspection topics. |
rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Do you know what the issue with this is?
![]() Maybe reminder for some seasoned inspectors too. I ran into this in a house built in 1988 last week. Goodman Mfg model #HCC050ND3R |
| Find an InterNACHI certified New Hampshire Home Inspector (and anywhere else in North America) |
Hundreds of these are still in service today. Your model number does not contain an "X," which are the recalled furnaces.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 10/12/09 at 12:09 PM.. |
Jeff...dude you got some good eyes or I just dont know how to blow that pic up to view...but my first look wouldve been its location so close to the access and the wearing of socked sandals to do an inspection.
I think Jeff used his powers of reasoning more than his eyes as he figured like any good detective that Ralph had a reason for including the model number.
Now as for that missing drip leg........... |
Haha...I just looked again...Shame on me....I didnt see that the model # is posted under the pic. Talk about snake in the grass.
Nope. I'm not THAT young Paul
CA Home Inspectors can go a lifetime without seeing a drip leg. They are not required in most jurisdictions out here. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
You should however wear appropriate clothing.
Sandals with socks are appropriate clothing for Humboldt County
http://www.cpsc.gov/cpscpub/prerel/prhtml01/01189.html |
They are used to trap condensation in the line and prevent valve damage despite the alt name (aka) dirt leg. |
Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
No, many manufacturers REQUIRE them in their installation instructions as do water heater manufacturers. Chuck |
Pardon the thread drift. . .I haven't seen this. Can you post an example?
Semantics! Don't confuse a drip leg with a sediment trap. Different animals for different requirements even though they are constructed the same. I agree that drip legs (for trapping moisture) are only needed if the local gas supplier requires them. Sediment traps on the other hand are required by IRC G2419.4 as well as many appliance manufacturers for all applications. I know CA uses their own versions of the code so they may be different. See the AOSmith water heater installation instructions below (see, even they confuse the terms somewhat).
Bradford White, GE and others for water heaters below is a Bradford White installation manual see page 15 section 1. http://www.bradfordwhite.com/images/...-47656-00B.pdf We all know manufacturers installation guidelines trumps Local AHJ every time. Chuck |
| Home Inspector Listings | jbowman | Miscellaneous Discussion for Inspectors | 230 | 3/21/12 9:35 PM |
| Inspector listings by county | rcarter | Miscellaneous Discussion for Inspectors | 8 | 8/22/09 10:40 AM |
| Flooded Basement Inspectors in Coeur d’Alene, ID 83815 | rspriggs | Ancillary Inspection Services & Additional Topics | 0 | 1/9/09 3:34 AM |
| California Home Inspections | whandley | Miscellaneous Discussion for Inspectors | 17 | 6/4/08 12:28 AM |
