Check it out.....
Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
| Need a home inspection in New York? Check out InterNACHI's listing of New York certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
What is the source of this list?
I'm in the middle of a builder-buyer suit over defective insulation installation. Have a meeting with "quality control" Friday. Can I use this list as a standard of proper installation? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
http://www.naima.org/main.html www.insulate.org Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
measter is a non-member guest and is in no way affiliated with InterNACHI or its members.
Thanks Kevin!
That's good stuff. BTW check out my new ebooklet I have for sale on ebay titled - 25 Checkpoints for Inspecting Insulation. Only $9.95! Mark |
Thank Kevin!
I defiantly saved that for future reference.
Thanks Kevin |
Thank you Sir!
Kevin,
good article but should it be named 25 checkpoints for inspecting fiberglass insulation |
Back in the 1980's Owens-Corning had insulation installation training for contractors. The walls that they would install batts in had an environmental chamber on the other side. Some installers thought they were doing a very good job until they saw the heat loss shown in the finished wall by IR. See if you can find any documents from that period. A couple of things not said in the mentioned document are: 1) When installing a "friction fit" batt into a cavity (15" batt into a 14.5" wide stud cavity), push/compress the batt into the outer corners and then pull it back out to be flush with the face of the studs. If this is not done the batts drag on the sides of the studs and leave a small triangular void at the outside corners of the cavity. 2) If a batt is not intended to fill a cavity (not as thick as the cavity), ensure that it is installed in full contact with either the inner or outer panel surfaces enclosing the cavity. If there is space on both sides of the batt (installed in the center of the cavity), convective forces will be enhanced and full R value not attained. This may be the case with paper-faced batts when stapled along the side rather than the face of the studs. The side stapling creates a space on the inner side of the cavity. If the batt does not fully fill the cavity and be in full contact with the sheathing, creating an outer space, convection losses lessen the R. Last edited by Brian A. MacNeish; 1/29/10 at 1:51 PM.. |
Wow good stuff.
Thanks Kevin House 2 Home LLC 503-602-1420 HomePros@House2HomeLLC.ORG Protecting Peace of Mind One House at a Time IAC2 Certified IR Certified A favorite place on Google Maps |
That goes for me too! I have installed many a roll in my time, and I never "imagined" the actual performance of the install! It makes me "cringe" when a contractor refutes performance of a "crappy" install! "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
When doing the estimate I noticed that one of the slopes had the plumbing vent run vertically up though it. This was a retrofit plumbing system probably installed in the 1920-30's. To re-finish the broken plaster around the pipe, they needed to provide a plaster base......they stuffed in an old potato sack!!! Just before doing the IR scan, I mentioned to the thermographer (An engineer with an AGA 700 series Thermovision.......anyone else remember these?......about $40+ grand in the 1980's.....OUCH!!!) that there was an area in a slope that we could not blow completely.......this was the only part of our installation that showed a cold spot or a miss!! A few years prior to our retrofit work, the owner had ripped out, re-wired, insulated, etc and installed a new kitchen in the rear addition. I had this scanned since it was a small area. The insulation work done by the owner was actually pretty bad to the point that he said he should have consulted with or hired us to do the fiberglass batt & air/vapour barrier work when he did the renovation!! |
Not so good insulation install. Batt insulation with gaps
thanx for the info Kevin, saving that for future reference. Good additional info Brian, my reference list will have 27 items.
Joe Keresztury JWK Inspections Home Inspections in San Antonio, Schertz, Cibolo, New Braunfels, Boerne and all surrounding South Texas areas www.jwkhomeinspections.com |
| Insulating Your House from CMHC | mkyriacou | Canadian Inspectors | 10 | 2/14/10 3:50 PM |
| Poly being applied to Basement walls | dvalley | Interior Inspections | 40 | 11/24/09 10:49 PM |
| Options in selecting materials for basement construction | wdevries | Canadian Inspectors | 2 | 8/4/08 1:30 PM |
| New Old Insulation | rcooke | Canadian Inspectors | 1 | 12/13/06 5:25 PM |
