How do you know you have an air duct leak problem? After all, you can’t see air leaking inside the walls, floors and ceilings of your house!
For a limited time, get 50% off on our “Beat the Heat Inspection Special”, now through June 2014. We will perform an infrared thermal imaging scan of your HVAC system and conduct a building pressure test to see if you have an air leakage problem.
If you do, we can qualify you for a $500 TVA rebate on necessary repairs.
