Out of all the websites I visited which write about air infiltration into houses and the corrective measures to be taken to correct that situation, only 2 ( and I visited over 40) mentioned that making a house too tight can cause new problems.
If I was to find the sources of air leaks into a house I would explain that sealing ALL air leaks could be worse than leaving them in place, but if one really wants to stop all air leaks (or most of them) I would recommend an HRV or ERV be installed. Any comments would be appreciated. Gabe |
| Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Air sealing ceases when additional air sealing is not cost-effective, when the air-leakage-reduction target is reached, or when the minimum ventilation level is reached.
None of this can be determined without a blower door test. Ideally, a house is completely air tight with all required amounts of fresh air provided through mechanical means where it can be conditioned and filtered. Rarely is this ever achieved. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
My point was that most of the websites I visited and who use infrared cameras, are talking about finding leaks and lack of insulation or the presence of moisture and the fact that finding the above and correcting them will save the home owner money and make the house more comfortable. Except for 2 sites, no site mentioned that making a house too tight could make the situation worse. Also, practically non of the infrared camera users mentioned the use of a blower door test. Gabe |
Lack of insulation has nothing at all to do with air leakage. Insulating an air bypass simply filters the conditioned air as it leaves the building. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
"The sealing of air leakage is very cost effective and can pay for itself in the first year from energy savings that the sealing will generate."
This is a quote from an inspector's website. No mention of the consequences.... |
There are no "consequences" if you do it right. A blower door test is essential. An infrared camera is an optional tool to use in addition to a blower door.
We don't have an equivalent to BPI in Canada (unfortunately) but we have NRCAN which is somewhat similar but without the teeth Also, what do you use to find the actual leak locations when you use a blower test? Thank you for your replies so far Gabe |
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
That is why I post here because hopefully people would not be threatened by someone far away. Gabe |
rspermo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Gabe,
You are correct! Many home inspectors do not totally understand the actual complexities of house air leakage. Every change to a house must be viewed in relation to what it may do to another part of the house. For example, to foam the rafters of an existing house without looking at the HVAC sizing would be a mistake. James is correct - the only way to actually quantify the home's leakage and air change per hour is to do a blower door. |
http://www.conservens.ca/resources/p...lder-Homes.pdf In the 1980's while running an insulation/airsealing company, we were installing good exhaust systems and instructing our customers on controlling interior moisture problems from basement dampness, not drying clothes inside/venting dryers to exterior, not storing wet firewood inside, covering aquariums, not too many plants, etc |
As for your comment that NO HOUSE IS TOO TIGHT, why else would newer houses need mechanically assited air exchangers (HRVs)? Too tight is obviously a relative term but let's assume that an older home can be sealed to the level of a new house, wouldn't you agree that if an HRV is not added that house WILL be too tight to the point that it will be uncomfortable. Gabe |
http://www.mitsubishielectric.ca/en/hvac/m-series/specifications.html Heat Pumps Get More Details</SPAN> ![]() MSZ-FE12NA Y 2,800 ~ 12,000 3,000 ~ 21,000 ![]() We had an energy audit on our 1400 sq. ft. Home Electric Base board heat . Fully Finished Basement Gas fire Place . Sealed and insulated as recomended On recommendation of audit Person we put in a Mr. slim heat pump. it heats our home upstairs great ,Electric heat kicks in at about 14°F/-10°C. I think we save about 70~ % on our heating and the AC is I think 23 seer and it is great . Easy 3 hour insulation no changes in Basement cost in Canada about $3,300.00 and about $1,400;00 return from the Government . Attached Thumbnails
Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
| IAQ pumps | eziminsky | General Inspection Discussion | 16 | 12/28/10 3:10 PM |
| Florida Licensing Bill - Action Soon | jburkeson1 | Legislation, Licensing & Legal Issues for Inspectors | 250 | 7/1/10 4:50 PM |
| Meth House? | tallen | General Inspection Discussion | 27 | 4/6/09 6:21 PM |
| Family's house is infested with mold | rspriggs | Ancillary Inspection Services & Additional Topics | 6 | 1/28/06 2:05 AM |
