Old 5/9/13, 11:08 PM
Charley L. Bottger's Avatar
Default Analyize these
Dave A here is some info for you this would have had me scratching my head if the owner had not been present and answered some quetions for me
These images were from the interior looking at the exterior walls A/C
operating Delta T was 14 degrees the wall studs were metal with dry wall that one could see.
Question why can you not see the wall studs with that much delta T??????
analyize-these-ir_6624.jpg   analyize-these-ir_6628.jpg   analyize-these-ir_6629.jpg   analyize-these-ir_6630.jpg
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
580-268-3340
Old 5/10/13, 7:55 AM
Default Re: Analyize these
Originally Posted by rstrand View Post
Thermal break, no studs touch both inner and outer wall?
They have to touch the inner wall
580-268-3340
Old 5/10/13, 8:12 AM
Marcel Gratton, CMI Marcel Gratton, CMI is offline
Staggered wall studs install.
On The Level Inspection
Gatineau, Québec
Old 5/10/13, 8:18 AM
Nope they were a standard wall install nothing special about them
580-268-3340
Old 5/10/13, 8:21 AM
Without talking to the owner my clue would have been the size of the A/C units there were 2 on this 5K+ home a 4 ton and a 2-1/2 ton
580-268-3340
Old 5/10/13, 11:29 AM
Jeffrey Moore Jeffrey Moore is offline
How long has the AC been running and Delta T reached?
Jeff Moore
www.quantumhomeinspections.com
Flir (ITC) Level II Thermographer
Mesa, AZ
Old 5/10/13, 11:49 AM
Peter C. Russell's Avatar
How old is the home?
Russell Inspection Services LLC
New Hampshire state license # 57
Level I Thermographer, ITC
Building Science Thermographer, ITC
Commercial Inspector, ITA
Certified Septic Evaluator, GSDI #148
www.newenglandthermalimaging.com
www.russellinspectionservices.com
www.nhsepticinspection.com
Serving Alton, Alton Bay, Wolfeboro, Laconia, Gilmanton, Gilford, Meredith, Center Harbor and the entire Lakes Region
Old 5/10/13, 12:43 PM
Cameron Anderson's Avatar
Cameron Anderson Cameron Anderson is offline
Does it have something to do with where the Delta T was measured or was it 14 in the room you took the photos?
Cameron Anderson
Integrity Home Inspection
Truth. In Real Estate.
Since 2004
Bachelor of Architecture, U of I, Urbana IL
Illinois Licensed Inspector
www.aaintegrityhomeinspection.com
www.homeinspectionpeoria.com
Old 5/10/13, 1:15 PM
David A. Andersen's Avatar
Mass.
Though we think of metal suds as highly conductive, there is little mass to conduct heat across the wall cavity.
Metal studs are more energy efficient than wood...
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
BPI# 5015804
Old 5/10/13, 1:23 PM
BTW: this is in direct conflict with all the miss-information posted on the internet that says otherwise...
So don't start posting all that miss-information here. Thanks.
Do the math. How many BTU's can pass through 16ga metal 3.5" long? (actually longer if you flatten it out).
This is about "volume" of heat energy, not the "rate" of heat energy transfer.
Metal also has a lesser ability to absorb heat energy than wood.
The amount of heat that passes through a length of thin metal is also widely displaced across a wide area where it contacts the sheetrock. Harder to measure because the BTU/mass is not sufficient to increase the temp of the sheetrock.
BPI# 5015804
Old 5/10/13, 2:13 PM
All the math in the world woud not have helped in this situation because behind the drywall all exterior walls and the ceiling had plywood installed to the interior with drywall attached to the plywood as the owner stated one can hang pictures on the wall anywhere.
As I stated above this would have had my thinking cap on had not the owner informing me before hand. I have never had a wall covered with both drywall and plywood on the interior side
Not many homes the size of this one in OKla with 110 degree summers with some humidity that can be cooled with the size of the units that were in use
580-268-3340
Old 5/10/13, 2:28 PM
John Ritter John Ritter is online now
built houses and remodeled kitchens for many years and all kits had plywood behind sheetrock. Hang boxes any where you want to.
Need a home inspection in Rhode Island? Check out InterNACHI's listing of Rhode Island certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/10/13, 2:48 PM
I hear they do things like that east of the mississippi just not out here
580-268-3340
Old 5/10/13, 2:55 PM
Juan C. Jimenez Juan C. Jimenez is offline
Hey Charley,
Is that little yellow square in photo four a switch?
Juan Jimenez
A House on a Rock Home Inspections LLC
God. Family. Home.
804-269-4321
Richmond Home Inspector
Chesterfield Home Inspector
Petersburg Home Inspector
Richmond Radon Testing
