Old 2/8/08, 10:20 PM
Carl Pennick's Avatar
Carl Pennick Carl Pennick is offline
Default Any Ideas what this is.
I found this today with the IR camera. It is a inside drywall, there is no damage to the wall or stains. There are no water pipes inside it and the wall backs onto a closet. We did find termite tubes in the garage I am thinking that this could more termite damage.
Thanks
Carl
www.wisemovehomeinspection.com
Carl Pennick
Lighthouse Point, FL
954-946 2737
407-928 8489
Florida Licensed Home Inspector #65
NACHI #04072098
ICC #5294144
Certified Master Inspector
Old 2/8/08, 10:25 PM
cgoyette cgoyette is offline
Please Note: cgoyette is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Any Ideas what this is.
wild guess...snake in the wall
Or active termite chute.
anyway both "wild" guesses!
Curt
Old 2/8/08, 10:27 PM
Peter C. Russell's Avatar
Carl, did you check it with a moisture meter? just as back up. But from what you said it could be termites, less sheetrock behind the paper would result in a higher temperature but that's depending on your delta t.
Keep us posted.
Old 2/8/08, 10:37 PM
Yes it was checked a moisture meter no problem there. I did find a leak in a closet behind the shower but that was the other side of the house.
Carl Pennick
954-946 2737
407-928 8489
NACHI #04072098
ICC #5294144
Old 2/8/08, 11:07 PM
sradabaugh sradabaugh is offline
Carl,
I see that the temp in Orlando was 75 today, which is close to the temp of your measurement. What are the conditions before during and after the inspection. Did you guys already turn on your furnaces with such a chill in the air? What kind of wiring did the home have? Hard to determine the reason for the anomaly without some background. Recent rain?
-Steve
Old 2/8/08, 11:16 PM
William Warner's Avatar
William Warner William Warner is offline
Are you sure it's not a branch circuit with a load on it?
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Old 2/8/08, 11:23 PM
No I thought of that but there was no elec near it.
Carl Pennick
954-946 2737
407-928 8489
NACHI #04072098
ICC #5294144
Old 2/9/08, 1:08 AM
gporter's Avatar
gporter gporter is offline
Carl,
I say termites
Gary Porter
GLP's Home and Mold Inspections
321-239-0621
Certified Commercial Mold Inspector
Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford
Orange County, Seminole County, Volusia County, Osceola County
www.homeandmoldinspections.com
Old 2/9/08, 11:37 AM
David A. Andersen's Avatar
You mention things that are "not in the wall". How do you know this?
I have found piping for hot water loop systems in the strangest places.
I have found overheated electrical wiring.
I have found HVAC refrigerant lines inside and outside on many, many occasions.
Any other photographs/ scans? How about some information on the attic/crawlspace investigation.
Kurt, you can't see snakes in the wall. They're cold blooded animals. They're the same temperature as their surroundings. Unless you can silhouette them.
Old 2/9/08, 11:43 AM
Talking Re: Any Ideas what this is.
I knew they are cold blooded but seems like if it was on the move up a wall it might be a different temp (moving from outside in)....I am not sure how much of a difference it takes to make a COLOR change like shown. But Termites was my other guess.
it was a "wild" guess...
Curt
Old 2/9/08, 11:47 AM
ldapkus ldapkus is offline
I had a similar pattern on an inspection yesterday and it was a whirlpool tub leak from the bathroom above.
Roy D. Cooke, Sr's Avatar
I do not think termites have any temp difference .
From what I have read it is those nest it is the Bacteria that are in the stomach of the fermenting ones that show heat.
...Cookie
Old 2/9/08, 12:11 PM
Chuck Lambert Chuck Lambert is offline
Unmoderated Guest
Please Note: Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
Plumbing vent pipe, appliace flue, central vacuum pipe, electrical. What ever it is it is big or warm enough to creat a temp difference on the SURFACE of the drywall. As stated before did you look in the attic to see what was above this location?
Any chance at a reflection?
Chuck
http://www.nachi.org/forum/attachmen...1&d=1202573599
Old 2/9/08, 12:37 PM
I did go in the attic. Yes there was a roof leak but not near this area. Like I said the WDO/WDI inspector found termite damage here there and everywhere in the house. Which is why I am leaning towards it being them. I will state that I cannot be 100% sure of the problem and further evaluation is needed.
Buyer said within 30 minutes of the inspection she was not buying the house paid me my check and said I will see her next week when she finds another house. Her realter was the listing agent as well and she told him he can have the report she does not need it.
Carl Pennick
954-946 2737
407-928 8489
NACHI #04072098
ICC #5294144
Old 2/9/08, 7:59 PM
David P. Valley's Avatar
Curt
Termites are considered cold blooded insects, but they can absolutely generate heat? Termites are hosts to bacteria, which live in their gut, and these bacteria help break down and digest cellulose, the main component of wood. It is this digestion and chemical reaction that generates the heat.
That’s why infrared technology and termite inspection makes the location of termites much easier thus allowing Thermographers to target the specific areas where termites are located and make the treatment effective.
But in this particular situation, the runs are too straght to be Termite tunnels.
My belief is that this is an elbow area of hot piping behind that surface.
What are some of the marketing ideas that worked wdevries Canadian Inspectors 8 4/16/07 10:32 AM
Ideas Wanted jmckenna1 Miscellaneous Discussion for Inspectors 18 2/2/07 7:42 PM
