Old 4/4/08, 7:22 AM
John Snell John Snell is offline
Please Note: John Snell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Argon Depletion in Insulated Windows
We have been seeing more and more evidence of argon depletion in insulated windows. Normally windows show an "edge loss" signature or, if the seal if broken, the entire window is affected. Argon depletion shows up—about 5-10 years after the window is installed—as a thermal anomaly in the center of the window. Summer images and images taken from inside show similar patterns but different heat flow. As the argon, a small-molecule, escapes out the seal (due to gas pressure equalization), air components (larger molecules) cannot make their way back in.
The result, in larger windows, is a bowing of the two panes of glass together; on smaller units there is less give and the windows often implode. When I showed the building owner the attached image yesterday, he said "I wondered how those three windows got broken last fall!"
Window manufacturers will often replace windows still under warranty showing this kind of signature—especially with a thermal signature as evidence. My colleague, Rob Spring, and I wrote a paper on the topic which I'd be happy to share for anyone who would like further reading. This, by the way, is just one of the topics we cover in our Level I and Building Specialty training courses.
And, yes, there are significant problems in this building with the insulation too! We are seeing a pattern related to air leakage past fiberglass insulation and, at the top, the icicles that result from similarly caused heat loss in the roof sections.
Thermally yours,
John Snell
ASNT NDT Level III #48166
Snell Infrared
800-636-9820
802-229-9820
http://www.thesnellgroup.com
http://www.IRTalk.com
http://www.thermalsolutions.org
Old 4/4/08, 7:27 AM
ldapkus ldapkus is offline
Default Re: Argon Depletion in Insulated Windows
Thanks John.
Do you like Windows XP rcooke Canadian Inspectors 46 2/2/08 4:54 PM
Free Software Office type products bmerrell Special Discounts for InterNACHI Inspectors 2 12/31/06 11:51 AM
Free Office Software Eqiv. For Download bmerrell Miscellaneous Discussion for Inspectors 4 12/31/06 11:47 AM
More water, different windows Brenda Exterior Inspections 12 9/22/06 2:55 AM
