Old 5/6/10, 2:44 PM
John Snell John Snell is offline
Please Note: John Snell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Article in Home Energy Magazine
Home Energy Magazine recently published a new article I wrote: "Infrared Thermography, What Works and What Doesn't Work." My intent was to talk about some of the challenges we face when inspecting buildings as well as to offer some tips for getting better results when conditions are not ideal. See more details at: http://www.homeenergy.org/article_pr...__Thermography.
The article is currently available only to subscribers (free later to anyone), and I would encourage you to become one as it is a great magazine always packed with very practical information. Rates are $75 online/print and only $85 for both.
Thermally yours,
John Snell
The Snell Group
www.thesnellgroup.com
www.IRTalk.com
800-636-9820
Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/7/10, 7:24 AM
Banned
Default Re: Article in Home Energy Magazine
Was subscribing to it in the late 1980's.
Old 5/7/10, 9:31 AM
David A. Andersen's Avatar
Very good point and article!
I was doing a water intrusion inspection (out of dire necessity) yesterday in the sunlight.
I told the client that John Snell would slap my knuckles with a ruler if he knew what I was doing!
The client spent $24,000 on engineers to fix water leaks around windows of his new house last year. After 15 inches of rain last weekend, water started flowing again! If I didn't get out there following these weather conditions, I may not have had another opportunity so I elected to try to do this job under adverse testing conditions.
Though he is a military pilot and uses Flir imaging on a daily basis, it didn't dawn on him until yesterday to find someone to scan his house (even though he thought about flying is helicopter by ) so there were several days of extreme sunlight on the building prior to my arrival.
It was extremely difficult to locate water intrusion in the extreme sunlight.
Saturated wall, window and hardwood flooring was easy to evaluate with electronic moisture testing (once you knew where to "stick it") however thermal imaging anomalies where extremely subtle.
I see many thermal scans posted that come directly out of the camera and are not properly tuned.
In the scan below we were concentrating on moisture intrusion below the windowsill which was flowing out from the wall plate inside the garage. Note the electric switch as the scan is tuned from the automatic camera settings.
There was an opening in the wall behind the electrical box that was sealed.
There were also numerous moisture entry points where window remediation practices failed.
The client had already started re-caulking window cracks before my arrival which hindered a visual inspection.
The delta-T and delta-h were practically nil.
To say the least, this was an extremely challenging diagnostic.
Camera sensitivity and resolution becomes critical under these circumstances and extensive use of computer software manipulation is absolutely necessary.
We must know our limitations and control our clients expectations when attempting diagnostics under marginal conditions!
BPI# 5015804
Old 5/7/10, 9:53 AM
Mike G. Howard, CMI's Avatar
Mike G. Howard, CMI Mike G. Howard, CMI is offline
Excellent images David. Your level and span was bang on.
Old 5/7/10, 10:19 AM
This is the actual auto camera scan to tuned scan I used.
BPI# 5015804
Old 5/7/10, 5:41 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Nice work Dave.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Orange County Home Inspections whandley California Inspectors 12 5/18/11 6:35 AM
Hiring a Home Inspector mkyriacou Canadian Inspectors 7 4/24/09 4:26 PM
California Home Inspections whandley Miscellaneous Discussion for Inspectors 17 6/4/08 12:28 AM
