Old 9/3/08, 6:35 PM
Barry Adair's Avatar
Default Avoid broken equipment
The FLIR wrist strap design is flawed.
I slipped in an attic and released the imager to obtain another handhold to avoid a catastrophic fall...the hinge broke, released the assembly from the imager and allowed it to drop leaving me with wrist strap and access door assembly and no imager...luckily it was a short fall into insulation...no permanent damage to the imager but I'll have to "duct tape" repair until new assembly is delivered...I'm going to get a neck strap that will screw install at the threaded hole under the bolometer
Be careful out there
hth
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 9/3/08, 6:54 PM
Dale Duffy's Avatar
Default Re: Avoid broken equipment
Barry...what the heck you want for 4-50G's?-----
Old 9/3/08, 7:07 PM
James F. McKee's Avatar
didn't your gramma ever give you those clippy things that went around your wrist that you could snap on things You didn't want to lose...oh...maybe you didn't grow up where there was snow and You had to wear gloves....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 9/3/08, 7:40 PM
Barry,
What the hell, just get a new camera
With all that commercial work, you're going to need a better one anyways.
Kevin
Kevin A. Richardson
Level III Infraspection Institute Certified Infrared Thermographer®, #7493
301-942-4610
www.richnspect.com
www.infrared-diagnostics.com
www.thehomegreenteam.com
Old 9/3/08, 10:59 PM
If you were in the attic, why did you get off the walk platform??
Old 9/4/08, 10:58 AM
Dan,
To further investigate in detail my suspicions...but you assume I was off the platform...not the case...the portion I stepped on was not properly secured and teetered as weight was applied...problem was I assumed two points of contact, feet and one hand was sufficient...bad on me for assumption
Truth be known I will get off a platform whenever I feel the need calls for further investigation...I appreciate your concern but you can save the SOP adherence diatribe for others...I like to drive fast and take chances...
hth
Total FLIR replacement part cost TT&L+S&H $41.14
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 9/4/08, 2:36 PM
Brian E. Kelly's Avatar
hth
So let's see if I got this right. The strap on your wrist broke and you dropped a camera. So now you want a STRONGER strap that you will anchor around your NECK. Hmmmmmmmmm?
So perhaps you slip and the camera gets caught, what gives first?
Old 9/4/08, 3:27 PM
Jeffrey R. Pope's Avatar
Thanks for the warning. I just checked mine and noticed this. . .
avoid-broken-equipment-20080904_16.jpg   avoid-broken-equipment-20080904_17.jpg
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/4/08, 5:32 PM
BUMMER, Jeff
Exact same location....hmmmmm...do I smell a class action and product recall...your shark or mine?
GOT TAPE?
Thanks AstroBoy I'll Just get me some ROPE! no sense wasting good money on a stinkin' neckstrap
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 9/4/08, 6:50 PM
Charley L. Bottger's Avatar
Some things one just does not do. Tug on Superman's cape, take a whizz against the wind and hold the camera with a cheesy wrist strap. I took a look at the strap and a look at the purchase price No way would rather fall through the ceiling than damage my camera be a lot less costly. It stays in my hand
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 9/4/08, 8:29 PM
Mine did to until the event...seems like tugging on his cape would be safer than his tights
I'm on the beneficiary list of your policy, right?
ADAIR INSPECTION
972-487-5634
TREC # 4563
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 77 5/10/12 6:13 PM
What do you think? Can this work for you? jtedesco1 Electrical Inspections 21 2/26/11 2:00 PM
Download the videos here all about physics and electricity jtedesco1 Electrical Inspections 5 9/14/08 3:58 PM
Where is it written.... bgromicko General Inspection Discussion 21 1/19/08 9:02 PM
Dwelling and Commercial Electrical Equipment jtedesco1 Electrical Inspections 4 1/10/08 6:46 AM
