| Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Preparation must also include inspecting for the presence of asbestos anywhere in the building envelope that could be disturbed. Also, instead of removing ashes from the fireplace or wood stove one can also cover them with wet newspaper since any remaining dust is likely to become airborne.
Nick,
Is there any need to comment on the fact that things can be drawn into the building enveloped such as mold, asbestos, allergens, attic dust/insulation, pollutants, etc... ? Is the inspector liable for any of these issues? To say these things can NEVER be drawn into the house is naive IMHO. John McKenna, CMI (TREC #4565)
Nick,
A few items I would address in your article: -50pa is a standard for BPI or HERS (Resnet) testing procedures. 75pa is the standard for large building (commercial and industrial) testing via ASHRAE, ASTM, USACE and AABA. -CFM is usually only the starting point for calculations. ACH, EqLA (US and LEED), EfLA (Canadian) and a host of other numbers are usually the end result, not CFM. This also depends highly on the weatherization program as to what number is used at the end of the day. CFM @ air flow (pa is not the only one used, just the most common) is just straight air flow, where many of the other numbers take in consideration the volume or square footage of the structure. -USACE standard is .25CFM/sq ft at .3in of water gage (75pa). 1500 CFM is a generic number that is often used for a threshold of leakage. -ASTM (E 2178 ) standard is an air barrier not to exceed .004 CFM/sq ft at .3 in wg (75pa) -ASTM E-779 is the actual testing procedure that is followed. It calls for an average leakage rate of no more than .25cfm/sq ft at 75pa through depressurization and pressurization. Then divide the average measured air leakage flow rate in both directions by the surface area of the enclosed envelope by the continuous air barrier of the building. -As a side note to ASTM E-779, there was already an ASTM standard in place for use of thermography before the Resnet standard. That test has to be done in accordance with ISO 6781:1983 and ASTM C1060-90 (1997) and finally ASTM E 1186-03 is the procedure standard for air leakage site detection. -blower doors have other uses in the clean room integrity testing and fire suppression markets. Those applications have their own set of standards and procedures. -longer term base lines in conjunction with a longer term testing procedure can also baseline out wind (to a certain point) and other factors...including stack effect. -In addition to air density and viscosity, items within the structure are resistant to flow and take up volume within the structure (volume is used for ACH and other related numbers). This calculation can be accomplished via the N factor calculation. Some systems have this ability built right in to the unit while others have to use external software for this calculation. -structures with swamp coolers have to have the supply and/or returns sealed off. -As James stated, one of the biggest safety concerns is asbestos. Those structures can only be pressurized and even then it really should be abated first. Jason Kaylor – JJ VP of Specialty Products 877/207-1244 AC Tool Supply Home Energy Audits Blower Door Cellulose Insulation Machine Tramex Moisture Encounter Plus Last edited by jkaylor; 9/17/10 at 12:21 PM.. |
JJ |
What you would not know, since it cannot be seen or measured by an IR device, is the fact that the pollutants that you are referring to are continuously flowing in and out through air leaks that only a blower door can measure. The tester does not want to dirty carpets or have draperies knock delicate things from shelves and window sills under his watch, so he will take care to ensure that the condition of the home is as he found it when he leaves. Thus, he will take care to protect these items. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
JJ |
blower door testing because they have seen first hand the health affects it had on their clients and even themselves. This debate is going on behind the scenes by a lot of people. John McKenna, CMI (TREC #4565)
I am with John on this one, I am not as experienced as he is, however my limited exposure to blower doors is similar. I am not sold on the benefits being greater than the risk.
The real problem in the industry I see is that people think they can just pick up a blower door, a BPI or Resnet certification and then out and get to work. A strong background or re-education in building science is a must. JJ Last edited by jkaylor; 9/17/10 at 1:40 PM.. |
I'm sure that the guys claiming to do "energy audits" with nothing but IR cameras will oppose the use of a blower door to anyone who will listen. I just don't happen to be one.
Depressurization within the home is a naturally occurring phenomenon and the use of a blower door to measure air leakage and stop it is safe and effective. To continue to use your clothes dryer and/or air handler to suck in pollutants does nothing to help anything. Neither does taking an IR image of 10% of the 300 different points that need to be sealed. But the most important use of the blower door comes into use AFTER the leaks are sealed and the need to determine the sufficiency of the remaining ACH to safely operate combustible devices comes into play. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
I agree with this statement, but to add another point, it also assists in keeping the frauds (contractors & pretend EA's with no BD's) at a minimum (before & after tests for work completion verification), those selling and installing windows come to mind... I like IR cameras, but they are only one part of your diagnostic tool chest as an EA...
I usually find these statements are made by people who have not experienced blower door testing and are just assuming. |
It is naive to say it never happens and is not a consideration. Did you do lab test to verify your opinion? It is common knowledge that leakage in return ducts in the basement and crawl spaces can introduce indoor pollutants into the rest of the home, such as dust, radon and mold spores, etc... Why would a blower door not be capable, in some cases, of introducing pollutants into the home? John McKenna, CMI (TREC #4565)
Executive Director - Master Inspector Certification Board 25 Yrs Constr Exp - 13 Yrs Home Inspector Exp American Home Inspection - East Texas. Last edited by jmckenna1; 9/18/10 at 2:04 PM.. |
Furthermore, anyone who gets into this business should have the proper training and related experience so if you do run into a situation like you described and you observe a condition that might be hazardous obviously you don't do the test. |
| New article: Blower Door Testing | inxil | InterNACHI & RealMatcher Blogs | 0 | 9/17/10 3:30 AM |
| Aerogel: Please proof this new inspection article. | gromicko | Green Building Inspections | 0 | 3/15/10 3:38 PM |
| Lighting Quality. Please proof this new inspection article. | gromicko | Green Building Inspections | 0 | 2/26/10 11:48 AM |
| Roy the proof you asked for | wdevries | Canadian Inspectors | 55 | 7/8/08 10:30 AM |
| Are electricians supposed to use these tools as per 70E? | jtedesco1 | Electrical Inspections | 27 | 12/15/07 3:40 PM |
