Old 4/10/09, 9:56 AM
Default BPI Class in VA
I'm attending this BPI Certification class in Virginia if anyone is interested.
http://www.vsbn.org/
http://www.vsbn.org/docs/200905_BPITrainingFlyer.pdf
If you live in the state of VA you get a discount!!
Should be a great class!!!
Kevin
Kevin A. Richardson
Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493
301-942-4610
www.richnspect.com
www.infrared-diagnostics.com
www.thehomegreenteam.com
Find an InterNACHI certified Maryland Home Inspector (and anywhere else in North America)
Old 4/10/09, 4:59 PM
ldapkus ldapkus is offline
Default Re: BPI Class in VA
What is the difference between BPI and RESNET Training. Are your audits QA'd (page 3) by a BPI provider. It seems that is you are RESNET Rater you still have to get QA'd annually and pay them a percentage. WTF???
Old 4/10/09, 5:13 PM
Linas,
This is a BPI class not RESNET. I'm not sure about the RESNET training requirement or the QA you are referring to.
As far as I know RESNET was originally designed for New Construction Energy Audits. BPI on the other hand is for pre-existing homes. Although, they have recently teamed with one another to come up with a joint standard for pre-existing homes.
If you are looking to get into the residential energy inspection arena, then BPI is the way to go. However, there may be others who disagree.
Kevin
Kevin A. Richardson
301-942-4610
www.richnspect.com
Old 4/10/09, 5:45 PM
Peter C. Russell's Avatar
Originally Posted by krichardson View Post
Linas,
Kevin
I agree Kevin.
Old 4/10/09, 8:29 PM
David C. Macy's Avatar
If you are RESNET certified you have to pay $50 for every energy audit to pay for there/your QA.
Seems like a lot of time and money and when your all done you make about $5 an hour.
I need to check the BPI out. I think Saturn offers both of the certifications.
Old 4/10/09, 9:13 PM
jrivera's Avatar
jrivera jrivera is offline
Please Note: jrivera is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hey, CMC is only 20 bucks and you don't have to pay anyone to come out and check your work.
Mic
Old 7/20/09, 11:56 AM
Tyler Johnson Tyler Johnson is offline
Please Note: Tyler Johnson is a non-member guest and is in no way affiliated with InterNACHI or its members.
Well there is a difference between BPI Certification and BPI Accreditation. An individual gets a BPI Certification, and a business becomes BPI Accredited. The difference basically being that BPI Certification tells a client that you know the process and have proven that you can do the process, however accreditation indicates that you follow the procedures and follow quality assurance guidelines and pay certain fees (plus accredidation requires at least Building Analyst certification plus one other specialty - usually Envelope Professional).
As far as the difference between RESNET and BPI Building Analyst training, RESNET is definitely more associated with new homes with their HERS rating assesment. The HERS rating is a point system that incorporates various factors and tests you conduct throughout a home to give it a number, that number then becomes an energy star rating which is marketable for new homes. BPI Building Analyst training teaches you how to examine existing buildings for proper ventilation, health hazards (combustion appliance zone testing, CO testing etc.), and air leakage testing - with a blower door after whic the assessor will give a report indicating all of the retrofits the occupant should make.
Old 7/21/09, 6:00 PM
Jason Kaylor Jason Kaylor is offline
Send a message via Yahoo to jkaylor
That is the route that I normally recommend to people. Daryl over at Saturn is about as knowledgable as you can get in the energy auditing industry. Most people shy away from the Saturn training because of the 8 weeks of online training before the hands on in MT. If you want their complete package it is $2100. That is BPI certification (as Tyler pointed out that is not accrediation), Resnet / HERS. They will also do the blower door and duct blaster training. I am 99% sure that also includes your initial field audits done on site in MT. Call Saturn to confirm that. Their website is a little confusing. You will see programs from $595 to $795 on the site. Once you add them all up with txt books you are looking at $2100.
I also highly recommend Clean Edison if you just want to go the BPI route. It isn't cheap, but it is really good. $1595, and they throw in a 4th day for the blower door training. Clean Edison is all over the country, and is the largest LEED prep exam training facility for LEED in the country.
One other standard that really needs to be taken in to consideration is the NAHB Green Building Standard. It recently gained an ANSI certification, which gives it teeth. Not to mention that the NAHB has almost 500k members. So just like the NRA they can make things happen. If you plan on doing the upgrades or just want all the certifications you can get your hands on that may help you some day, then the NAHB standard probably will be one of the bigger ones over time.
To avoid a lot of the dis-information flying around about auditors make x amount of money per job/week/hour/year or that energy audits are free in my area check out http://www.natresnet.org/ & http://www.bpi.org. You can also chat with energy auditors at the Saturn message boards at http://srmi.biz/bpt/ and http://www.energyauditortalk.org
Jason Kaylor – JJ
VP of Specialty Products
877/207-1244
AC Tool Supply
Fluke Infrared
Testo 327
UEI Meter
Makita Tools
Bosch Tools
Retrotec Duct & Blower Door
2 Day IR Class Coming To Toronto jmckenna1 Inspection Education & Training 0 6/3/08 6:28 PM
2 Day IR Class Coming To Toronto jmckenna1 Thermal Imaging, Infrared Cameras & Energy Audits 0 6/3/08 6:25 PM
Commercial Electrical Inspections jtedesco1 Commercial Inspections 29 1/12/08 5:03 AM
Dwelling and Commercial Electrical Equipment jtedesco1 Electrical Inspections 4 1/10/08 6:46 AM
Prolab Mold Class gwells Ancillary Inspection Services & Additional Topics 1 9/20/06 7:32 PM
