OJ Utter is a non-member guest and is in no way affiliated with InterNACHI or its members.
I am curious. Of those of you who have bought cameras. Who here has bought a camera and then upgraded? If you have or are planning to what camera are you going to and why?
Hi OJ,
I purchased a B-Cam SD, took the Building Sciences class and immediately called Flir to return it and upgrade. I new I wanted better resolution and such and went with the ThermaCam B400 w/high temperature upgrade. I have not been disappointed InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
And because I sat next to Larry in class, and I couldn't get away with swiping his new camera, I upgraded to the same res. diff. camera.
I started out with the B-cam as level 1 and purchased the BX-340 before I took my level 11 training and If I decide to go level 111 I will upgrade again to the P series.
Larry, I'm just curious....Why would you need a higher temperature (248 degrees F) than you previously had (212 degrees F)? All house temperatures (including Electrical) will not exceed the 212 degrees F. anyways. Even if the Electrical maxed out your camera temperature settings, you'd obviously have an issue. The only component that would get hotter than that would be the boiler/furnace. Most people who go with the higher temperature cameras are working around high tension wiring or mechanical equipment. Last edited by dvalley; 2/16/09 at 7:29 AM.. |
Someone, talk me into upgrading my B-2 and why?
I may do more with the local utility companies and others where it will be needed. BTW, my imager is capable of 350 C with the high temp option. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
The equipment it is used on may normally run above the 212 degree F limits of the camera. The camera detector is not capable of wide spans without going into saturation, so there are levels bracketed for specific use (Ranges of temp). If you are not doing quantitative scans, and need to do a high temp application, you can make a filter from a plastic lid (like the old coffee can lids) that will keep your camera from going into saturation by filtration of the emitted energy. The letter "B" in your camera model indicates that your camera is set up for the temp range most likely found in Building applications. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
I echo some of the same reasons for upgrading to a B360 from the entry level BCAM-SD.
'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
Great. I mentioned 248 degrees F., because that is the lens that that particular camera comes equipped with. I see you went with the upgraded version. I haven't found a reason to upgrade my camera as of yet. I'm loving my IR camera (and it's findings) more every day as I utilize it. |
I dug down deep and started with an EX320. Haven't felt any compulsion to upgrade. Though I do wish I had a wide angle lens too.
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
I had a customer ask, the other day, to upgrade his EX320. I told him to stick with it unless he wanted something like this http://www.aikencolon.com/Electrophy...as_c_1119.html For anyone that has a 320x240 camera that is doing the job now for them I would wait until the 640x480's come down in price. Plus .05C (50mk) sensitivity is already on a few units for under 20k, the Fluke TiR4 is 15.5k right now, and those will be coming down as well. Personally I would keep my 320x240 and spend the money on advertising / potential customer education on IR. Jason Kaylor – JJ VP of Sales 877/207-1244 AC Tool Supply Fluke Thermal Imagers FLIR Thermal Imagers Fluke TiR1 Resources FLIR B60 Resources Retrotec Duct & Blower Door |
It's good to see more and better options coming on the market for quality imagers. Increased competition should help a lot with driving pricing down.
When they get $75 for a plastic replacement lens cap and $55 for a wrist strap, you know that they are working with some pretty generous margins Of course the downside is that having IR will be less of a differentiator for those who already have and market them. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
Even though the B200, B250, and even the B360 may not have the sensitivity specification of the FLUKE camera but in ergonomics, ease of use, weight, durability, size, and options these camera again beat the FLUKE hands down. The FLUKE cameras can only use a specific brand of cards, the batteries don't last what the specification sheet says because in the manual it gives a warning that you can only get the specified battery life with 50% screen brightness. Plus just in the file size itself you can use up a lot of memory space. Again I would warn against anyone buying a FLUKE camera to save just a few hundred dollars. You will gain back that money in time saved onsite and afterwards reporting with a FLIR camera.
OJ Utter Level 3 itc Thermographer www.utterprecision.com |
OJ -
Thanks for telling us our Flukes ONLY take a certain brand of memory cards. I didn't know that. Since I have 3 different cards FOR my Fluke - AND use them all - How will I know which KINDS don't work. |
| Courier left Thermal Camera at Door! | jbettencourt | Thermal Imaging, Infrared Cameras & Energy Audits | 9 | 9/24/08 7:44 PM |
| I wouldn't recommend this IR camera to anyone... | bgromicko | Thermal Imaging, Infrared Cameras & Energy Audits | 6 | 6/3/08 11:29 PM |
| razir thermal FLIR infrared imaging camera for energy audit and home inspectors | Will H. Roberts | General Inspection Discussion | 4 | 4/16/07 12:13 AM |
