I am up to 1147 images on my second camera thought it was strange to be able to actually see the Goodman on this heat pump don't remember ever seeing it before
John Snell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Looks like you are reflecting a different temperature background. I've used this as a way to label things, actually. Once I did a building with 500 windows of 4 types. We used brass house numbers on nails on a board to "label" each one in the thermal image. By the way, it doesn't work if the background is the same temperature as the reflector! I've learned that the hard way more than once.
Differences in color can also be used outside if the sun is shining as you get differences in absorption and heating. Thermally yours, John Snell ASNT NDT Thermal/Infrared Level III #48166 Snell Infrared 800-636-9820 802-229-9820 http://www.thesnellgroup.com http://www.IRTalk.com http://www.learnnewsolutions.com/ |
John I don't think there was any reflection going on this heat pump had just started up in its heat mode when I snapped this image the condenser actually being the evaporator was about 42 degrees with outside ambient about 55 degrees this was taken right before darkness set in the letters were on the hail guard and somewhat raised allowing air to flow around the plate creating a different temp on the plate
My best, John |
Different emissivities between text and background of the label, I suspect.
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
| Getting Started with Infrared | jwisecup | General Inspection Discussion | 6 | 4/17/10 10:25 AM |
| Look out John M here I come | cbottger | Thermal Imaging, Infrared Cameras & Energy Audits | 14 | 12/28/08 12:01 PM |
| Texas Needs a Boot | cbottger | Thermal Imaging, Infrared Cameras & Energy Audits | 1 | 12/26/08 2:52 PM |
| Ohio I know we can do it | cbottger | Thermal Imaging, Infrared Cameras & Energy Audits | 0 | 12/26/08 1:31 AM |
| NEW! E-Book: Making Money with Infrared for Home Inspectors - $39.99 | sramos | Thermal Imaging, Infrared Cameras & Energy Audits | 8 | 6/19/08 1:55 AM |
