Here's another brain scratcher...
Why are the curtains on fire (warmer than the surroundings)? Winter - Unoccupied house and HVAC had been on for aprox 20 minutes - 9 am - window facing covered porch
Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
and sun shines in warming the curtains ....Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Sorry about that cookie... I just added some more information which might help.
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
What was the curtain material made of ? Where they just shear, or a heavier material ?
2 to 4 degrees is not a huge difference It could be that the heating system would make a difference in curtains in open air..... Cookie
Good post gets us all thinking Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Think of the curtain materials and their thermal properties. This can be applied to many other materials. Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
I'm new to the IR stuff....but depending on the material, that could be reflection couldn't it?
[I need to invest in a camera and training, soon!] |
I wouldn't consider the curtain to be on "fire." The temp range is 60 to 44, so the curtains relect the actual inside temperature compared to the lower tempeature of the window surface and surrounding wall area.
Did you manually tune your camera? Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
Brian asked the right question.
The material is thin and thus heats up faster than surrounding thicker materials. Curled flakes of paint, curled corners of wall paper, hollow core doors (as compared to solid core), etc will do this. Hence my opinion on the vinyl siding question... a possible reason (which may not be correct) why it is cooler than the rest of the siding is because it may be a thicker material than the other panels thus not heating as fast as the others. Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
The panel seemed to not be as "attached" (you know slip joints ect...) as the rest of the siding. It was in the morning and the OA Temp was on the rise. We may be seeing too much sensitivity on the part of the camera (and we are all looking for more!). Maybe the BC AM is all we need for HI application? |
