Old 3/3/09, 9:49 PM
kweiss's Avatar
kweiss kweiss is offline
Default Dallas Inspector finds shower leaks using Infrared Thermal Imaging
More examples of the power of infrared.
Noticed the moisture in the door trim immediately on initial scan when shower had just been turned on for testing. Confirmed moisture in the trim with moisture meter. Location was unusual in my experience - I have found other leaks in this development - and was subtle.
But it was enough to cause me to Spend extra time investigating the shower. Let the shower run for a while aimed in different areas of the shower seat. That produced the second and third pictures - these confirmed/prove leakage as water was visible on floor, in addition to being visible behind tile to the infrared.
dallas-inspector-finds-shower-leaks-using-infrared-thermal-imaging-ir-suspect-moisture-trim-near-shower.jpg   dallas-inspector-finds-shower-leaks-using-infrared-thermal-imaging-ir-shower-leak-1.jpg   dallas-inspector-finds-shower-leaks-using-infrared-thermal-imaging-ir-shower-leak2.jpg   dallas-inspector-finds-shower-leaks-using-infrared-thermal-imaging-moisture-confirmation.jpg
Kevin Weiss
Professional Inspector
Level I Infrared
www.AbsoluteInspections.net
www.homeinspectorsplanotx.com
www.homeinspectorsmckinney.com
Absolute Inspections, LLC
972-463-0887
Old 3/3/09, 10:04 PM
John McKenna's Avatar
John McKenna John McKenna is offline
Default Re: Dallas Inspector finds shower leaks using Infrared Thermal Imaging
Very Nice.
Executive Director - Master Inspector Certification Board
25 Yrs Constr Exp - 13 Yrs Home Inspector Exp
American Home Inspection - East Texas.
Old 3/4/09, 8:35 PM
Nice find Kevin..........
Many custom showers are installed improperly, I make it a habit to turn the water on and let it run for about 15 minutes prior to inspecting same......I do the same with whirlpools and garden tubs before going under crawlspaces.......most of the time I find small leaks which typically would be undetected......infrared is great....... good inspecting habits are even better, doing both is CYA.
Again, nice job.
Old 3/4/09, 8:52 PM
ldapkus ldapkus is offline
I found one today.
dallas-inspector-finds-shower-leaks-using-infrared-thermal-imaging-p3040045-small-.jpg.JPG
Old 3/5/09, 9:37 AM
William J. Decker's Avatar
Here is a little trick I use, when scanning.
a) Turn on all the bathroom vent fans and the range hood and the dryer to air fluff. This produces negative pressure in the house and makes air leaks more visable.
b) Rub every water fixture (shower, tub, basins, sinks, etc) with hot water. If there are any leaks, they will show up as hot, which is easier to see with IR as an anomoly. Let it run for awhile (usually, while I do the kitchen appliances). Also good for separating defects (drain and pan leaks vs. roof leaks).
c) always check tile shower enclosures with a deep probimg moisture meter. Especially check aroun the fixtures (under them). Now I will be adding exterior corners of the tile construction, based upon these pictures.
Hope this helps;
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 3/6/09, 10:44 AM
jbettencourt jbettencourt is offline
Please Note: jbettencourt is a non-member guest and is in no way affiliated with InterNACHI or its members.
That is a nice job! I did an inspetion with Thermal Imaging add on yesterday, but I didn't need the camera to catch this one. When we walked in the basement bathroom I mentioned that tile showers are notorious for leaking when not properly built or maintained and that I had my suspisions about this one. We walked into the storage room next to the bathroom, moved a couple empty boxes and found this.
dallas-inspector-finds-shower-leaks-using-infrared-thermal-imaging-32-evelyn-street-033.jpg   dallas-inspector-finds-shower-leaks-using-infrared-thermal-imaging-32-evelyn-street-034.jpg
Old 3/6/09, 6:24 PM
kweiss's Avatar
It was a good leak week - or bad depending on your perspective. Found two more yesterday (the IR was icing as they leaked visibly) and one today. Today I spent the day in a development I have worked in a lot JUST doing Shower Moisture checks. Checked 6 and found one leaking. Was a good day.
Kevin Weiss
Level I Infrared
972-463-0887
Old 3/6/09, 6:31 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
I did an inspection for a client that was worried about an old water stain on the wall. I was able to conclude that there was no longer a leak. The date on the toilet next to the stain, showed it was less than a year old. Judging by Infrared, the lack of surface rust on the shutoff, and supply line, I determined that the leak was the Old toilet, and had already been replaced. Client was happy.
Old 3/7/09, 9:26 AM
Bryce W. Jeffrey Bryce W. Jeffrey is offline
Kevin:
I would be interested in knowing what type of camera you are using. Those pictures are very good.
Regards:
Bryce
Old 3/8/09, 1:36 PM
kweiss's Avatar
They were taken with a Fluke TiR1. I have been very happy with the photo quality of the TiR1.
Kevin Weiss
Level I Infrared
972-463-0887
Old 3/9/09, 8:59 AM
Kevin:
Thank you.
How about it illinois cbottger Thermal Imaging, Infrared Cameras & Energy Audits 13 8/19/11 6:07 PM
Texas Needs a Boot cbottger Thermal Imaging, Infrared Cameras & Energy Audits 1 12/26/08 1:52 PM
Ohio I know we can do it cbottger Thermal Imaging, Infrared Cameras & Energy Audits 0 12/26/08 12:31 AM
