Old 6/21/08, 11:25 AM
Charley L. Bottger's Avatar
Default David A. Here is one for your files
Had town house with two A/C's I felt the suction line while touring the outside the line felt to warm unit had been running for a while. Decided to explore a bit to see if the IR would pic up anything inside at the coil. The A-coil and furnace was less than two years in age the condenser was a 1997 different brand mix and match.
You can plainly see the top of the A-coil was not being fed Starving the Evap. This coil had a TXV with external equalizer.
I installed my gages just to see what kind of pressures we were running. The outside ambient was 88 degrees back pressure was 70 PSIG head was 240 PSIG. I did not pump the unit down.
I see three possible problems without further testing which I did not do. TXV not feeding properly, Low Freon charge, Discharge valve leaking back into the suction side.
The Pic of the condenser was the one for this A-coil I removed the cover of the coil box and snapped the images while the unit was operating and before any temp changes could occur because of the cover being removed.
david-here-one-your-files-ir_0477.jpg   david-here-one-your-files-ir_0472.jpg   david-here-one-your-files-ir_0474.jpg   david-here-one-your-files-2609-dans-court-enid-6-20-08-028.jpg
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Chicago Area Homebuilder Files for Bankruptcy ldapkus Miscellaneous Discussion for Inspectors 1 10/23/07 9:26 AM
Help merging .txt files mboyett Miscellaneous Discussion for Inspectors 6 4/17/07 11:02 AM
Square D Files Lawsuit to Prevent Counterfeiting jtedesco1 Electrical Inspections 2 5/26/06 6:36 PM
