Old 1/16/09, 10:16 AM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
Default DOE Recommending Thermography Inspections
Found this page on the DOE site this morning.
http://apps1.eere.energy.gov/consume.../mytopic=11200
Old 1/16/09, 11:34 AM
John McKenna's Avatar
John McKenna John McKenna is offline
Default Re: DOE Recommending Thermography Inspections
I like this part... I use this all the time...
"In addition to using thermography during an energy audit, you should have a scan done before purchasing a house; even new houses can have defects in their thermal envelopes. You may wish to include a clause in the contract requiring a thermographic scan of the house. A thermographic scan performed by a certified technician is usually accurate enough to use as documentation in court proceedings."
Executive Director - Master Inspector Certification Board
25 Yrs Constr Exp - 13 Yrs Home Inspector Exp
American Home Inspection - East Texas.
Old 1/16/09, 2:00 PM
Dennis R. Goudreau Dennis R. Goudreau is offline
Thanks Scott
Old 1/16/09, 5:29 PM
Banned
No ever seems to mention this line:
"Thermographic scans are also commonly used with a blower door test running. The blower door helps exaggerate air leaking through defects in the building shell."
Not only does the blower exaggerate the air leaks but reverses air exfiltration at points that IR won't pick up because the exiting air is the same temperature or very close to the interior drywall temps......therefor the exfiltration points are missed. Also with IR you cannot quantify the the extent/amount of air leakage and what the potential is for improvement......Is the house a sieve with high potential for air sealing savings or is it quite tight......in which case, move on to other issues.
Old 1/16/09, 5:38 PM
David P. Valley's Avatar
Is this type of IR scan patented also?
Old 1/16/09, 6:07 PM
Jason Kaylor Jason Kaylor is offline
Please Note: Jason Kaylor is a non-member guest and is in no way affiliated with InterNACHI or its members.
The blower door with an infrared camera is also required for EnergyStar energy audits. We have had a ton of people calling in about getting set up for this type of energy audit.
Jason Kaylor – JJ
VP of Sales
877/207-1244
AC Tool Supply
Fluke Thermal Imagers
FLIR Thermal Imagers
Fluke TiR1 Resources
FLIR B60 Resources
Retrotec Blower Door Systems
Retrotec Duct Blower Systems
Old 1/17/09, 7:00 AM
Banned
Not by me!!!
Old 1/17/09, 7:07 AM
Originally Posted by Brian A. MacNeish View Post
Not by me!!!
Ya know I was joking, right?
Old 1/17/09, 7:14 AM
Barry Adair's Avatar
won't be equivalent to a blower door but closing all fireplace flues (don't make this mistake unless you want a cleaning bill) and turning on all hvac fans and all exhaust fans, kitchen, bath, laundry... will create enough negative pressure to reveal most thermal infiltration anomalies during a home inspection as long as there is a good enough indoor outdoor difference in temp
not talking air leakage, energy audits, just breeches in framing and insulation issues...
agree that blower door is optimal
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 1/17/09, 7:15 AM
Banned
Yep! But might be worth looking into it! There's money to be made. Have you been paying your IR fees to that other HI company?
Old 1/17/09, 7:20 AM
i'm using my IR patent fees to assist with the bailouts
ADAIR INSPECTION
972-487-5634
TREC # 4563
Banned
Originally Posted by badair View Post
won't be equivalent to a blower door but closing all fireplace flues* (don't make this mistake unless you want a cleaning bill) and turning on all hvac fans and all exhaust fans, kitchen, bath, laundry... will create enough negative pressure to reveal most thermal infiltration anomalies during a home inspection as long as there is a good enough indoor outdoor difference in temp
Yep! Unless it's a very loose house......then you won't be able to generate very much indoor negative pressure.
*Don't forget to turn off all combustion heating sources also.
Old 1/17/09, 7:23 AM
that's why i said hvac fans
should have been fans ONLY, ok
way to early to be pickin'
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 1/17/09, 7:33 AM
Banned
OK!!!! OK!!!! Just didn't want some newbie pulling combustion gases into the house.
Orange County Home Inspections whandley California Inspectors 12 5/18/11 6:35 AM
East Coast Inspectors needed for Draw Inspections ASAP lendza Miscellaneous Discussion for Inspectors 39 2/17/08 10:09 PM
