The attached image displays three different drain pipe materials. The vertical pipe is cast iron, the elbow is galvanized steel and the remaining section is PVC. Question; why does the galvanized elbow appear warmer than the other materials? Emissivity?
| Find an InterNACHI certified New Mexico Home Inspector (and anywhere else in North America) |
Was hot water recently run?
Did it absorb, and transfer to its surface, the heat from that more readily? InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Warm water was running down the vertical section probably 15 minutes prior to taking the image. The PVC from the kitchen received drain water about 30 minutes earlier.
Steel section appears to have a thermal gradient. This is a good image that shows the thermal characteristics of different materials. The mass of the objects being heated along with the ability to transfer the energy are different for the three materials.
It's obvious that heavy duty cast iron will not conduct or retain heat like galvanized and PVC material does.
Will this question be on the test?
| No secondary (pan) drain in Attic Okay per builder | mgault | Inspecting HVAC Systems | 14 | 1/30/09 8:38 AM |
| Options in selecting materials for basement construction | wdevries | Canadian Inspectors | 2 | 8/4/08 1:30 PM |
| Inspector in hot water after approving unit without drain | rcooke | Canadian Inspectors | 7 | 2/20/08 3:59 PM |
| Child eviscerated by pool drain | mthomas2 | Ancillary Inspection Services & Additional Topics | 26 | 7/16/07 4:27 PM |
| French drain tied into main drain | rwashington | Plumbing Inspections | 6 | 2/16/07 11:04 PM |
