Couldn't figure out what where the burning smell was coming from.... went to the laundry room and located the culprit.
Dryer receptacle was reading 225 while the breaker was 56; turned off breaker and simply rerouted the lead wire and readings settled to around 120. Still not sure what actually was going on...... the dryer vent was free and clear and the dryer is fairly new. |
| Find an InterNACHI certified Mississippi Home Inspector (and anywhere else in North America) |
Has to be a loose connection, probably poor tension on the receptacle somewhere or a loose wire at the back.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
I fixed the loose receptacle however upon checking the wires they were tight as a drum.
I went ahead and called my electrician who will come check it out Monday. I am still getting readings of 230 plus....but only on one side of the receptacle and plug. I absolutely hate electricity...... I have had my share of shocks which have taught me to respect it better. lol |
On each hot side of the 240 volt circuit, you should be getting 115 (or so) to 120 volts between hot and neutral or ground. Is the above highlighted correct? |
It is most likely where the plug connects to the receptical.
Pull the plug and scan it. Take the outlet cover off and scan it. I can't make out anything on the scan you posted. Keep those numbers out of the way also. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
I agree with David Andersen's post. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
So correct.......Still too early after New Years to try to think deeply!! And............. I did an inspection ysterday PM. Perhaps should go back and check it over again. |
the focus is off on the radiometric, do you have other pics that show the outlet and plug better.
What ir cam did you shoot the picture with. ASNT Certified Level II Thermographer Certified Mold Inspector (Pro-Lab) Certified Mold Inspector IAC2 Certified Home Inspector INACHI 07040201 Commercial Property Inspection Certified Master Home Inspector 2008 InterNACHI member of the year Magnum Property Inspection Inspect it before you buy it 613 813 2353 mobile We use and recommend Home Inspector Pro Software HomeGauge Software |
rbibler is a non-member guest and is in no way affiliated with InterNACHI or its members.
I put your image in my program. The image is out of focus. It will help you if you set up your photos with the camera in an Inverted Gray. Take a few images in that then if you want make your changes. Best Ron |
I have seen brand new double pole breakers bad more than a few times. A swap is quick, inexpensive. Temps are always different on circiuts showing different colors normal.
I think its the receptacle..... the chord nor the conduit is hot... only at the plug receptacle connection. Sorry for the picture.... I was screwing around with different palettes. Last edited by jhaynes; 1/4/10 at 4:30 PM.. |
| Dryer Vent Cleaning Montgomery County PA | nhagarty | Ancillary Inspection Services & Additional Topics | 0 | 1/11/09 12:23 PM |
| Dryer Vent Cleaning Chester County PA | nhagarty | Ancillary Inspection Services & Additional Topics | 0 | 1/11/09 12:22 PM |
| What is a 'condenser' dryer ?? | rcooke | Canadian Inspectors | 9 | 9/9/07 7:02 PM |
