Old 12/5/08, 5:25 PM
David Sorge's Avatar
David Sorge David Sorge is offline
Default EIFS and IR, would you call this out?
I found this on a home today with EIFS. The dark areas are obvbiously suspect. I checked with a Protimeter Aquant scanning meter and moisture was clearly elevated at these location compared to known dry areas. If this were stucco it would be a no-brainer for me but EIFS I'm not too sure about. What do you think?
eifs-and-ir-would-you-call-out-ir_0252.jpg   eifs-and-ir-would-you-call-out-ir_0257.jpg   eifs-and-ir-would-you-call-out-ir_0251.jpg
David Sorge (USN Retired)
FL License HI142
Infrared Certified Thermographer
Inspect-It 1st of Northeast Florida
Serving Jacksonville and surrounding communities
904-484-4847
dsorge@inspectit1st.com
http://www.dsorgeinspects.com
http://www.linkedin.com/profile?view...US&trk=tab_pro
We see RED...InfraRED
When we see RED...
You see $GREEN$
Ask us how?
Old 12/5/08, 5:35 PM
ldapkus ldapkus is offline
Default Re: EIFS and IR, would you call this out?
I invested in one of these for EIFS issues.
Old 12/5/08, 5:38 PM
And now I will too
Unfortunately I need to make a call on this as I'm writing a report. I think I may have enough information to at least recommend further evaluation.
FL License HI142
904-484-4847
When we see RED...
You see $GREEN$
Ask us how?
Old 12/5/08, 5:39 PM
Barry Adair's Avatar
What type system PB PM drainage or 1st generation?
Why the .85 emissivity?
Did you also use a Wet Wall Detector and probe these areas by any chance?
When was the last rainfall?
Had the irrigation system been run within 24 hours?
What was the dew point?
More questions than answers from me but I specialize in EIFS and would have to factually document all of these and more variables to determine what was going on for conclusive reporting.
You may want to refer this to an EIFS specialist...or come to the INACHI EIFS/Stucco course in Denver 12-15,16-2008
also looks like the terminated below grade a real NO NO
hth
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 12/5/08, 5:47 PM
Doug Edwards's Avatar
Barry,
Exactly! All questions that need to be asked and answered. These questions and protocols would be taught at an EIFS/Stucco certification course.
- John Stuart Mill
Old 12/5/08, 5:49 PM
hth
The emissivity shouldn't matter just to evaluate the patterns from what I've been taught. Is this correct?
No wet wall detector.
Irrigation system was enabled but the heads along this wall were clogged except for 1. No rain within last few days. From what I understand, the Protimeter ignores surface moisture.
Don't know the dew point but temp was approximately 60 degrees with 65-70 RH
FL License HI142
904-484-4847
When we see RED...
You see $GREEN$
Ask us how?
Old 12/5/08, 5:51 PM
Its not the type of EIFS with drainage and it's not really below grade...they just had mulch pushed up against the house a little too high.
FL License HI142
904-484-4847
When we see RED...
You see $GREEN$
Ask us how?
Old 12/5/08, 5:52 PM
Originally Posted by dedwards View Post
Barry,
C'mon now...a vacation would be nice but I'm busy.
FL License HI142
904-484-4847
When we see RED...
You see $GREEN$
Ask us how?
Old 12/5/08, 5:57 PM
Bob Elliott's Avatar
Are you punching holes in EIFS?
How do you patch it back up?
Old 12/5/08, 6:04 PM
Yes, Caulk
Old 12/5/08, 6:26 PM
I'm smack dab in the middle of my best December on record...but am taking advantage of this great opprotunity...and have some plans to use the studio examples and info gleaned to make the last half of this career better than the first half
I try to set E as close to subject materials as possible
If you don't have a hygrometer with wet bulb use a calculator many available online
Repeat if you're not sure REFER!
gone to suppercheck back later...
hth
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 12/5/08, 6:43 PM
hth
I used to set E precisely but since apparent temperature is acceptable for moisture evaluation I don't do it as often any more. I've found that it doesn't make any noticeable difference whn solely evaluating patterns.
I'm just going to refer it for further evaluation. The owner is a builder so I'm sure he knows someone that can check it out for him.
FL License HI142
904-484-4847
When we see RED...
You see $GREEN$
Ask us how?
Old 12/5/08, 6:45 PM
Finger food so I'm back but one handed
The Surveymaster Protimeter I have will read surface moisture to an extent, I'd understand and check your equipment out very thoroughly before I'd base report statements upon it.
I always check/calibrate the night before and recheck once onsite.
Tools, any tools are only as good as the operator and the results can and will vary dramatically with time of day and weather when it comes to exterior IR, especially EIFS due to the underlying insulation
Also real EIFS is 3/4" minimum foam thickness with 1/8"~3/8" base+finish coats this is beyond the depth measurement of my Protimeter without probes and would yield inconclusive results thus the usage of a Tramex wet wall detector to go as deep as 4"
hth
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 12/5/08, 7:02 PM
hth
I know my tools well but I agree... I don't feel that I have enough evidence to say anytnig conclusive. I don't believe that IR data and a moisture meter is enough. This is one of those times when saying next to nothing is the best thing to say.
FL License HI142
904-484-4847
When we see RED...
You see $GREEN$
Ask us how?
Old 12/5/08, 7:17 PM
What has me concerned about this the most is that I have a great Delta T...the framing is clearly visible. Its rare that I can see framing behind stucco unless conditions are just right.
FL License HI142
904-484-4847
When we see RED...
You see $GREEN$
Ask us how?
Hard board siding? sfalvey Exterior Inspections 23 11/29/10 2:41 PM
EIFS Assistance Please thance Exterior Inspections 7 2/2/08 12:39 AM
Need bad EIFS photos sspradling Exterior Inspections 18 12/2/07 5:06 PM
EIFS question tjansson Exterior Inspections 3 5/14/07 5:07 PM
