ddelaney is a non-member guest and is in no way affiliated with InterNACHI or its members.
I was contacted by an HOA with a large commercial building to perform an EIFS survey. To this point, i've performed IR on mostly single family homes. Any suggestions for larger buildings? Tips/tricks? Any information is very much appreciated. I am asking because this building has several caulk joints due to width and height, no overhang, all the common commercial traits.
Thanks in advance guys!!! |
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
rbibler is a non-member guest and is in no way affiliated with InterNACHI or its members.
Keep a eye out for thing that are connected from one unit to the adjacent unit. they will play off each other. Some one can be cooking in a lower unit and have a big effect on the unit above. you will need access to all interiors of the exterior walls you are imaging. have the on site guy have keys to all units along with letters sent out in advance that you may need access to interior. keep an eye out for dog and cats. have the owner control there pets.
Best Ron |
David,
That is a very good course!!! Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| There are over 12 types of stucco and EIFS | bgromicko | Exterior Inspections | 0 | 12/19/09 7:04 PM |
| EIFS/Stucco | mmerino | Exterior Inspections | 16 | 8/6/09 7:41 AM |
| Survey Results - National HI Conventions and Trade Shows | gwells | Miscellaneous Discussion for Inspectors | 3 | 7/31/08 7:48 AM |
| EBPHI Survey | Raymond E. Wand | Canadian Inspectors | 5 | 4/1/08 11:59 PM |
| Construction Draw Survey | Trey Sunderland | Inspection Hardware, Software & Publications | 0 | 4/11/07 9:22 AM |
