http://www.thermalimagingscan.com/IR...herization.htm
Energy Performance Audits for Clarksville Nashville and Middle Tennessee "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission Last edited by dandersen; 1/25/10 at 2:12 AM.. |
| Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Nice website Dave!!!
David,
Nice site, but I noticed two errors that you might want to fix. 1. Add in some examples: keep the reader interested: embed video: pictures of leaks or construction deficiencies. No IR at this point. 2. Insulation resists heat transfer as well as air leakage if installed properly. I would remove #1 and change the text in #2. Insulation is not an air barrier. I would inform your readers that air sealing prior to adding additional insulation is more cost effective. Just my 2 cents Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
Nice site Dave!!!
Thanks guys. I was looking for some sharp eyes.
I will be adding more, so keep an eye on me! Quote:
Anyone have a real good "Out the window" IR scan from the exterior (that they took)?
OK, I'm done messing with this page for now. Please check with your browser. I use Chrome. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission Last edited by dandersen; 1/24/10 at 10:44 AM.. |
Very nice web site, I like the way you are heading your business toward IR weatherization etc.
you might want to use the google keyword tool for your title bar. I am just guessing and didn't look, but I doubt IR is searched all the much. I would think "infrared" would be more searched.
https://adwords.google.com/select/KeywordToolExternal JJ |
Jason, This is my IR site. I'm adding on to it.
May consider a new site once I get things on the ground. Your correct though, however I do get many calls for energy audits off the IR part of the site, may get more if I change though! Thanks! "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
arook is a non-member guest and is in no way affiliated with InterNACHI or its members.
Nice site.
Your site reads that fixing leaking windows is a good investment. Do you mean that you are going to air seal them? or replace them?. If you're replacing them, I would disagree and say that the payback on replacing windows takes a long time. |
Fixed! Thanks...
Window replacement improves on some leakage if the windows are crap, and better glass can increase U-Values... "but in reality window-to-frame leaks are the greatest losses we find during our evaluations". Then I have a pic with the frame leaking bad! Should I say window replacement is a wast of money? That is what I was trying to slide in there! "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
| Home Inspector Listings | jbowman | Miscellaneous Discussion for Inspectors | 225 | 10/18/11 7:54 PM |
| Thermal Imaging Seminar-July 10- NYS Approved for Home Inspector CE | bmerrell | Thermal Imaging, Infrared Cameras & Energy Audits | 6 | 6/24/09 11:07 PM |
| Gov't Energy Funds Coming Down The Pipeline | jmckenna1 | Miscellaneous Discussion for Inspectors | 2 | 4/7/09 11:13 AM |
| Missouri Certifies Home Energy Auditors | jbushart | Miscellaneous Discussion for Inspectors | 7 | 11/20/08 12:44 AM |
