Here are a few images of heat loss (exfiltration) at exterior envelope.
Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
Kevin
I realize that you have been doing this longer than myself, but I took some pictures that are similar and was wondering if there is a reflection from the window? Your comments please Thanks Lawrence Olsen |
No I am refering to the lighter area above the windows.
Lawrence |
Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com Last edited by krichardson; 2/4/08 at 11:00 PM.. |
Thanks for that. I stand corrected.
If I could figure out how to get a picture on here I would post the one that I have. Lawrence |
Love to see your images Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
What camera do you have? Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
Hello Kevin & Lawrence,
Nice pics What time of the day or night are taking these readings. www.wisemovehomeinspection.com Carl Pennick Lighthouse Point, FL 954-946 2737 407-928 8489 Florida Licensed Home Inspector #65 NACHI #04072098 ICC #5294144 Certified Master Inspector |
Scans come out nice when you have a good Delta T. (70 degrees?)
It's below zero F there. The hot spots are -.76F |
I'm not sure how Lawrence tuned his camera, but my Delta-T was around 35 deg F. Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
http://www.nachi.org/forum/f58/try-brainteaser-25304/ |
Thanks guys
Mine were taken about 5 hours after sunset with a outside temp of -25C. (sorry for the metric). These pics were taken with a FLIR EX320 with a wide angle lens. The delta T that you are talking about is that outside temp from mid day to night or are you talking from inside to outside? Lawrence |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 72 | 3/12/08 12:19 AM |
| Energy Audit Article | ebadofsky | General Inspection Discussion | 1 | 2/2/07 8:04 AM |
