Old 2/19/10, 1:15 PM
Nick Gromicko's Avatar
Nick Gromicko Nick Gromicko is online now
Default Enhancing Energy Efficiency in Historic Homes. Please proof this inspection article.
Enhancing Energy Efficiency in Historic Buildings.
Find a Home Inspector
Need a home inspection in Rhode Island? Check out InterNACHI's listing of Rhode Island certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/19/10, 2:37 PM
Default Re: Enhancing Energy Efficiency in Historic Homes. Please proof this inspection arti
Great job, Nick; keep 'em coming!!!!
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 2/19/10, 2:45 PM
Doug Edwards's Avatar
One caveat that may need to be addressed, if not here, at least somewhere. Many areas, like here where I live and operate, have some very strict guidelines and requirements that are imposed on buyers and homeowners of historic homes. Any and all alterations, additions, upgrades, retrofits have to be submitted and approved by a Historical Society or committee before even applying for permits. Sometimes even the colors for paint have to be approved. I do a number of old historic homes within the Pensacola city limits, well over a hundred years old, but most around 80-90 yrs old. I have seen many go through this process and they find it can be very daunting and tedious at times. On the up side of this, these same people will provide the history and reveal resources for the buyers and remodelers.
Just FYI, This Old House magazine and website provides a plethora of resources for finding items, hardware, HVAC upgrades made specifically for this area of historical housing.
- John Stuart Mill
Old 2/19/10, 2:56 PM
John Snell John Snell is offline
Please Note: John Snell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Originally Posted by gromicko View Post
Air sealing is often the biggest bang for the buck in older buildings. Not just window and door weatherstripping but sealing in the basement and the attic in particular as well as the bypasses that are so common in older homes.
Thermally yours,
John Snell
ASNT NDT Thermal/Infrared Level III #48166
The Snell Group
800-636-9820
802-229-9820
http://www.thesnellgroup.com
http://www.IRTalk.com
Old 2/19/10, 4:07 PM
William J. Decker's Avatar
Agreed, John.
Around here, I have yet to see a house (new or older, sad to say) that had an ACH50 of less than 10 - 12. Seems like badly installed fiberglass insulation is the rule, rather than the exception. They they chink the window and door penetrations with fiberglass. Unsealed can lights and bathroom exhaust fans vented directly to attics and unsealed sheathing. The builders seem to believe that Tyvek does not have to be taped and that it does the air sealing.
I, heavily, recommend spray foam insullation. Good R value plus the added benefits of air sealing and water / vapor barrier.
That's just in my area, mind you.
Hope this helps;
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 2/19/10, 4:14 PM
dbelmont dbelmont is offline
Send a message via Yahoo to dbelmont
Please Note: dbelmont is a non-member guest and is in no way affiliated with InterNACHI or its members.
Originally Posted by wdecker View Post
Agreed, John.
I, heavily, recommend spary foam insullation. Good R value plus the added benefits of air sealing and water / vapor barrier.
Hope this helps;
But Will it's just a little hole. It won't matter.
We have a long way to go in getting folks to take energy efficiency seriously in most circumstances. It's a shame given the modern materials that make this effort a lot more successful with a little attention to detail.
Old 2/19/10, 4:47 PM
A little hole can cause a LOT of air infiltration, amd moisture infiltration, in our humid for three seasons climate.
And there are many "little holes".
Add to that the, usually, negative pressure conditions in modern houses (forced and induced draft furnaces and water heaters).
On you major point, I really agree.
Will Decker, CMI
Old 2/19/10, 7:16 PM
Peter C. Russell's Avatar
Don't forget, one of the most important aspects of air sealing is to determine the thermal boundary of the home.
Great comments!
Old 2/22/10, 4:19 PM
Rob London Rob London is offline
great comments, guys. Doug, that's a very good point
Researcher and Technical Writer, InterNACHI
Watch what the Democrats do... klott Miscellaneous Discussion for Inspectors 245 9/24/08 6:12 AM
Government mandate to thin the walls to save $10 bgromicko Plumbing Inspections 48 9/9/08 2:23 PM
Energy Audit Article ebadofsky General Inspection Discussion 1 2/2/07 7:04 AM
