Old 10/11/08, 3:44 PM
kweiss's Avatar
kweiss kweiss is offline
Default I finally found some
After 18 months of IR I finally found termites with it. As I don't do termite inspections due to the state licensing here in Texas it worked out well that my termite inspector was coming out to the inspection too. I showed him the area and he found the proof. (not sure if they will show on the picture - they are tiny after all - but he found live termites.
Cannot really explain why the IR anomalies struck me as they did, but I knew as soon as I saw them for some reason. Slight elevation in moisture when checked. Crappy differential because of weather this time of year and fact that gas was off so I couldn't run the heat to help the delta T. Would like to figure out a way to know for sure about this short of having the pest guy come out for occassions when he is not scheduled. Would hate to be recommending him when he wasn't there and being wrong. Will have to give it more thought.
finally-found-some-aiir0016.jpg   finally-found-some-aiir0025.jpg   finally-found-some-termites-2-.jpg.jpg
ID:	24581   finally-found-some-termites-1-.jpg.jpg
Kevin Weiss
Professional Inspector
Level I Infrared
www.AbsoluteInspections.net
www.homeinspectorsplanotx.com
www.homeinspectorsmckinney.com
Absolute Inspections, LLC
972-463-0887
Old 10/11/08, 4:53 PM
Default Re: I finally found some
I would put it my report (evidence of wood destroying insects....) and that same was verified by the termite inspector.....
Old 10/11/08, 5:00 PM
kweiss's Avatar
yup - me too
Kevin Weiss
Level I Infrared
972-463-0887
Old 10/11/08, 5:59 PM
David P. Valley's Avatar
Nice find Kevin.
I also located hidden termite activity with IR, but it was on a nice cold day. The infestation was obvious.
Old 10/11/08, 6:54 PM
Ron C. Bibler Ron C. Bibler is offline
Please Note: Ron C. Bibler is a non-member guest and is in no way affiliated with InterNACHI or its members.
Yes you can find sub-termites in walls. A Dry wood termite is another story. This can take a bit of time to do this. I have a FLIR B2 Camera.
I allso have a small space heater with a fan on it.
If you set the heater about 6 feet aways from the wall area your going to view. set the camera to auto. you will have 2 windows to work with the first one will be as the wall is heating up and then as the wall is cooling down. if you have active sub-termites/tubes on the back side of the sheet rock they will come into view for a brief time as the wall heats up then they will go away as the wall overheats for viewing. then shut off the heater view the wall. the tubes will show for a short time as the wall is cooling down.
This test will provide the inspector with evidence of just how far the termites are working in a wall, Ceiling and Flooring.
See the image attached.
Good stuff.
Ron Bibler
EXCELLENCE EXTERMINATING AND THERMAL IMAGING
WWW.EXCELLENCEEXTERMINATING.COM
www.santarosatermiteandpestcontrol.com
HEALDSBURG CALIF.
Old 10/12/08, 5:51 AM
David A. Andersen's Avatar
Ron, besides the termite tube, what are we looking at near the wall/floor?
We have cool at the floor and a hot spot at the baseboard.
My take is that there is moisture at the floor and it was heated with your spaceheater and held heat as the wall cooled?
Was this scan taken on the cool down? I would assume so.
I have not used the space heater technique much.
BPI# 5015804
Old 10/12/08, 3:50 PM
David you are correct this area has a mold and moisture condition. normal condition with sub-termites. this was on the heating up side of the test. the electrical main was just above this area. slab floor with the conduit behing the sheet rock. inside view of an out side wall... we had a slopping sidewalk condition directing rain water at this area over the years. this area was also a converted garage. the perfect storm. the areas you noted was sheetrock paper. heating up faster then the other areas.
try using a spaceheater some time work great to control the Delta T Of a room.
Best
Ron
Does an inspector pay for decay that was found because of probing? lagudo Exterior Inspections 22 5/10/08 9:17 AM
Does an inspector pay for decay that was found because of probing? lagudo General Inspection Discussion 24 5/7/08 1:01 PM
Finally found one that tripped the ALCI! jtedesco1 Electrical Inspections 5 2/1/08 9:41 PM
Panels of all types found around the USA! jtedesco1 Electrical Inspections 7 1/11/08 7:26 PM
Found in attic klott Miscellaneous Discussion for Inspectors 7 5/3/07 5:35 PM
