Old 1/15/09, 7:06 PM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
Default First Inspection
Just wanted to share some shots from my first IR usage and get some opinions.
This is a bedroom exterior wall on a two story home. The first floor is block the second is wood frame.
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 1/15/09, 7:08 PM
Greg Bell's Avatar
Default Re: First Inspection
This is the same room by the window on the same wall.
Greg Bell
Titusville, Fl
02111507
Old 1/15/09, 7:10 PM
Greg Bell's Avatar
This is around the front door.
Greg Bell
Titusville, Fl
02111507
Old 1/15/09, 7:12 PM
Greg Bell's Avatar
This was the ceiling in the second floor bath. There was no attic access for the second floor.
Greg Bell
Titusville, Fl
02111507
Old 1/15/09, 7:13 PM
Michael Larson's Avatar
I'm curious Greg.
Did you move that couch or chair out from the wall to get that shot?
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 1/15/09, 7:17 PM
Greg Bell's Avatar
Originally Posted by mlarson View Post
I'm curious Greg.
No the bed was away from the wall.
Greg Bell
Titusville, Fl
02111507
Old 1/15/09, 7:20 PM
Gotcha
I thought that might have been the reason for the cooler area due to lack of air circulation.
So never mind
Michael Larson
Hudson, WI
InspectraPro
and
Old 1/15/09, 8:01 PM
ldapkus ldapkus is offline
As far as the baseboard being cooler,it may be air infiltration. Your weather today was not real hot. Also the sill plate and trim (wood) show up cooler as do the studs in the walls. Here's a pic of air infiltration in a closet above a cold garage.
The colder areas above the baseboard may be lack of insulation or moisture. Did you check them with a moisture meter??
Old 1/15/09, 8:04 PM
klott's Avatar
klott klott is offline
If it is on a slab, that would explain the cooler perimeter...right? Air leak at door gasket.
"It's not what you believe that matters...it matters what you believe!"
Old 1/15/09, 8:24 PM
Greg Bell's Avatar
Thanks for the call from Barry and Linas. I really appreciate you guys sharing your knowledge with me.
Greg Bell
Titusville, Fl
02111507
Old 1/15/09, 11:56 PM
Mathew Hawley Mathew Hawley is offline
Congrats on your new services Greg. Your camera will pay for itself in no time.
Priority Home Inspections has teamed up with the Dish Network to give you a FREE Dish Network system. Log onto www.Free-Dish-For-You.com for all the details.
Priority Home Inspections, Inc.
321-368-9921
www.BrevardHomeInspector.com
www.AvoidAMoneyPit.com
www.BrevardInsuranceSavings.com
www.BrevardBuildersWarranty.com
www.PrioritySignPosts.com
Info@BrevardHomeInspector.com
Old 1/16/09, 6:23 AM
Greg Bell's Avatar
Thanks Matthew. I haven't seen you in a while. I hope that things are going well.
Greg Bell
Titusville, Fl
02111507
Old 1/16/09, 7:37 AM
David P. Valley's Avatar
Greg,
I detect cold air at this floor transition area quite a bit. It's caused from insufficient insulation inside the outer rim board/sill cavity.
This is my recommendation when I find these voids...
I recommend insulating the outer cavities of your rim joist area. Many homeowners are not familiar with the rim joist area, so let me explain. The rim joist area is the most outer portion of your flooring system below your living area. Basically, it’s the small wood cavities that are at the top of your foundation. As you are looking at the top of your concrete foundation, it is the first wood cavity where your floor joists are sitting on a wood sill and abutting the rim joist. See “Rim Joist Illustrations” in your report.
These rim joist cavities should be filled with either un-faced fiberglass batts or rigid board insulation, cut to fit snugly into the outer most portion of these cavities. Once this insulation is properly installed, it will become an effective insulation barrier that will improve efficiency at the most outer edges of your living area floors. Another more expensive option for insulating this area would be to apply a foam insulation into these cavities either by you or by a professional.
(A second floor would be worded differently)
Old 1/16/09, 7:46 AM
Needs additional weatherstripping.
Old 1/16/09, 8:07 AM
Banned
Originally Posted by dvalley View Post
Greg,
Do you ever check for cold air infiltration at this point. It may not be an insulation problem only. Insulation does not stop infiltraion/exfiltration but only slows it down.
These rim joist cavities should be filled with either un-faced fiberglass batts or rigid board insulation, cut to fit snugly into the outer most portion of these cavities. Once this insulation is properly installed, it will become an effective insulation barrier that will improve efficiency at the most outer edges of your living area floors. Another more expensive option for insulating this area would be to apply a (spray) foam insulation into these cavities either by you or by a professional.
The better way if you can afford the professional.
Attachment 26269
This graphic shows no airsealing.
Are you getting the blower door?
