Old 10/20/09, 12:10 AM
kluce kluce is offline
Please Note: kluce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default First IR picture for a buzzing breaker
Found 2 breakers buzzing and took an infrared picture of it.
First picture with the two wires is a double pole breaker going to the electric stove with one wire being 131 degrees and the other 86 degrees.
The second picture with four wires is one of two double pole breakers going to the electric furnace. One wire is 128 degrees and the the other wires are around 97 degrees.
Thought you might be interested.
first-ir-picture-buzzing-breaker-ir000221.jpg   first-ir-picture-buzzing-breaker-ir000223.jpg
Find an InterNACHI certified Massachusetts Home Inspector (and anywhere else in North America)
Old 10/20/09, 1:02 AM
mlehman mlehman is offline
Please Note: mlehman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: First IR picture for a buzzing breaker
Good Job Kevin!!!
Put that on the back of your Cube.
Old 10/20/09, 1:11 AM
Dale Duffy's Avatar
Hi Kevin,
I think if you ran that info by a Licensed Electrician he may shake his head...in case you think this might be significant issue.
Circuit Breakers making noise is not uncommon, and the temperature difference is certainly nothing I would make an issue about.
Many times a loose breaker and loose connection could cause the issue, I think I would have turned the breaker off and checked the connection at the bus and conductor before having someone come to the property especially for this item.
But you may have done that....nice find though.
Never hurts to check them, that's for sure.
Old 10/20/09, 1:20 AM
Dale, its not our job to turn anything off and check. Kevin did the right thing.
Old 10/20/09, 1:24 AM
Dale Duffy's Avatar
You do what you feel is right, and I'll do what I feel is right.
It might be the reason I have other Inspectors working for me and am booked a week in advance every month of the year...try it, you may like it.
PS. I have called Paul Abernathy years ago about this exact issue, I posted what Paul told me, I learned something that day, just passing the info along to someone who may not know the reasons stated above.
Old 10/20/09, 1:36 AM
dbucknavich dbucknavich is offline
Please Note: dbucknavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
Funny, sounds like an inspector's version of building code. "I inspected your house to the standards I am legally required to meet."
To each his own though. To exceed or not to exceed.
Old 10/20/09, 1:53 AM
John McKenna's Avatar
John McKenna John McKenna is offline
Good job.
BTW... what was the ambient temperature?
Executive Director - Master Inspector Certification Board
25 Yrs Constr Exp - 13 Yrs Home Inspector Exp
American Home Inspection - East Texas.
Old 10/20/09, 2:00 AM
Dale Duffy's Avatar
Originally Posted by jmckenna1 View Post
Good job.
127---
Old 10/20/09, 2:19 AM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
Originally Posted by dduffy View Post
Hi Kevin,
Sound advice Dale!
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 10/20/09, 5:59 PM
Hi Kevin,
It sounds like you would handle this differently than I am. In my opinion, the buzzing sound by itself is a red flag. Something is causing that buzzing sound and if it is from a loose connection, it should be addressed. It sounds like we can agree that the sound and one of the two legs being hotter than the other leg is likely due to a poor connection. While I did take an amp reading on each leg and tried to tighten the screw connection, I do not turn power off to a circuit and remove breakers to inspect, adjust and/or clean the connections. Regarding the IR picture, I feel the picture gives my client a good visual understanding then trying to explain amperage to her.
Regarding this comment
I hope this comment doesn't make you feel superior? Because having employees by itself doesn't mean **** in my eyes.
Best to all.
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 2 1/8/11 8:04 PM
Breaker Question rsole Electrical Inspections 6 11/23/08 10:57 PM
Electrical Guru Question? Breaker lock outs pdoane Electrical Inspections 4 9/7/07 3:05 PM
Double Tapped Breaker tjohnson3 Electrical Inspections 8 4/20/07 10:04 AM
