I have a rather LARGE commercial building with a roof that is covered in a white Acrylic material. The layers on this roof are (from bottom) :
1. Concrete Deck 2. Vapor/moisture Barrier 3. 3.5 inches Dow Board (that insulating type) 4. Acrylic overlay membrane (white) I know the prevailing wisdom is to shoot a flat roof at sunset/night..and this is how I have done all my others, but now I am wondering on this roof ..if it would be better shot in the morning, as the sun begins to load up this white acrylic cover. I would guess at this point the "colder" areas would show possible water damage, as they would be the slowest to thermally load. Or does the "color" make no difference? I would appreciate your thoughts. Thank you in advance. InterNACHI Building Inspector, Certified InfraRed Certified, Fluke and InterNACHI MidAmerica Therma Pros, LLC |
Hi Rob,
It can be done BUT there are many limitations and hurdles to overcome and understanding thermal loading and thermodynamics is paramount. I played like Peter Pan chasing my shadow on one I performed... These were early morning right at sun up. My shadow... you can see exactly where I was standing ![]() Object shadows... ![]() You're on the right track... and possibly comparisons between the two times can assist you in determining your answers. Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
OJ Utter is a non-member guest and is in no way affiliated with InterNACHI or its members.
General recommendations for inspections on roof is 2 hours after sun up or down down. I have seen that not always hold true though. I believe that the white roof will not absorb sun radiation as quickly but we may only be talking about a half hour difference or so. I would recommend waiting a little while after sun up for a day inspection and for night during this time of year you should be able to get there any time from now to 2 hours after sun down.
OJ Utter Level III Thermographer www.utterprecision.com |
IR Inspections of Flat Roofs is a previous topic that can be found in the Tip of the Week section at the IRINFO.ORG website. It can be found at the following URL: http://www.irinfo.org/tip_of_week_2002.html#t05182002 Several other Tips and Feature Articles pertaining to infrared inspections of roofs are available free of charge. As to your question regarding roof membrane color, do not confuse albedo with emiitance. White roofs will absorb plenty of heat from the Sun during daylight hours and should be inspected from around sunset until several hours thereafter. When inspecting after sunset, your actual window of opportunity will depend upon several interelated factors including, but not limited to: local weather conditions before and during the inspection, roof moisture content, roof surface conditions, and the sensitivity of your thermal imager. To ensure accuracy, all infrared data should be verified by invasive testing. To help ensure best results, you might also wish to obtain a copy of Infraspection Institute's Standard for Infrared Inspection of Insulated Roofs. This comprehensive 11 page document is available from the Standards Section of the Infraspection Online Store. Please feel free to give me a call should you require further assistance or information. Hope this helps. Jim Seffrin, Director Infraspection Institute 425 Ellis Street Burlington, NJ 08016 609-239-4788 SuccessIRies.com IRINFO.ORG IRINFOConference.com |
Thanks to all who responded. Jim I did purchase your specs for roof inspection. Very informative and will use sections of it in future specifications/quotes.
It did not however shed light on this particular question so I guess a bit of trial and error is in order. Now a quick last question: This roof is LARGE and I think I would like to use some flood lights at night to help in getting around. I don't think this light will make any impact on the thermal images but might help me from falling on things. The light itself should have no impact on the thermal load. So the question is: Can I use large floodlights at night when taking thermal images on a roof? Thanks again. InterNACHI Building Inspector, Certified InfraRed Certified, Fluke and InterNACHI MidAmerica Therma Pros, LLC |
I perform all my flat roof inspections 1 hour after sunset, no matter what color the roofing material is. As long as you perform these roof inspections after sun-down (having no sun reflection, will allow roof to cool down to normal temperatures), your IR camera will absolutely detect any moisture intrusion within the roofing material. As for the floodlight use...Light will not make a difference in IR readings as long as the flood light is not beaming in one location more than a few minutes, your IR readings will not be affected. I'd only be concerned with heat build-up at the lit-up areas of the roof. Simply keep the light moving. Here's a nice IR image of a roof leak that was occurring at a college in Massachusetts. They had no idea where the source was until I arrived....
Here's the same college at a different roof...
![]() Note that the moisture intrusion (on the underside of the roofing material) will be warmer due to the conditioned area below. |
David,
Two questions, is that a Duro-Last roof system? And are those walk pads loose or glued to the membrane? It has been my experience that moisture will be detected below walk pads if not glued to the roof membrane. Not necessarily a moisture issue, in fact if these pads are removed (if not glued) the moisture/water is visible. 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
Jim,
I believe Rob is referring to a Thermoplastic roof membrane. Are you of the opinion that a thermal scan can be performed on this roof membrane? I have never attempted a scan on a roof membrane such as this although I have visually inspected a few roofs with this system. I’m of the opinion that it would be difficult at best if not impossible to do a scan on this roof system. 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
Rob,
My advice for what it's worth is:
You could use LED flood lights, they produce almost no heat. There are several systems available. We do not sell them but check out Lowe's or Home Depot, they both carry them. David is right that light will mess with your eyes, but if you cannot see you cannot see. LED's are a lot more focused so the flood effect on your eyes will not be as bad.
One thing in all of these threads for flat roof inspections that I have noticed is no mention of fall protection. All of these commercial structures are required to provide you guys with tie offs for fall protection. Most of the time it is a cable or rope type of system around the outter edge of the structure. If they have one central tie off you can talk to the building owner about purchasing a retractable lifelife system as well. That will get you around the entire roof without having to constantly having to re-attach. I know HVAC service guys that have to get their own retractable lifeline systems then have the building owner provide a slightly elevated tie off for the retractable. My manufacture for fall protection is owned by 3M and if you guys have any questions on that stuff feel free to email me and I can forward it on to the right person in the area that the building is in. Jason Kaylor – JJ VP of Sales 877/207-1244 AC Tool Supply Fluke Thermal Imagers FLIR Thermal Imagers Fluke TiR1 Resources FLIR B60 Resources Retrotec Duct & Blower Door |
Fall Protection Usually required if working within 6' of roof edge if I recall correctly.
I think I paid around $150.00 for the basic set up. Any inspector who walks roofs should have one.
www.blackbearladder.com/bblweb/fall/rooferkitpdf Last edited by prussell; 2/27/09 at 9:16 AM.. |
That's a very good point Jason!
BTW Have you ever worked with a harness? It's cumbersome to say the least. 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
Here's the link I posted www.blackbearladder.com click on the fall protection link.
I agree Mario, they are a pain but save lives, not to mention if OSHA happens to be driving by and sees you without it you'll get fined. It happened to me and the fine was $1500.00 but I negotiated it down to $750.00. I'm not sure if there is a clause in the Reg's. I seem to remember roof inspection being excluded but I think that's more geared to set up for construction. |
| question??? Metal roof sweating | mjohnson6 | Exterior Inspections | 6 | 2/16/08 12:45 AM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
