Old 10/19/09, 10:16 PM
jmaxwell jmaxwell is offline
Please Note: jmaxwell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Flat Roof Inspections
Are any of you guys doing IR flat roof inspections? If so any advise would be appreciated.
Also have any of you attended the ITC roof inspection class?
Thanks
James Maxwell
Cenla Home Inspections
Find an InterNACHI certified South Dakota Home Inspector (and anywhere else in North America)
Old 10/20/09, 1:18 AM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
Default Re: Flat Roof Inspections
James,
The course is 2 days, hardly enough time here to cover everything. I suggest you take the course prior to actually performing a roof survey. You will find the class very informative! ITC also gives sound advice for personal safety while conducting a roof survey.
One piece of advice I can offer is: Back-up your findings with core samples.
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 10/20/09, 5:36 AM
Peter C. Russell's Avatar
Originally Posted by mkyriacou View Post
James,
Mario, how do you do a core sample, lets say it's a rubber roof with no access under it?
Old 10/20/09, 5:44 AM
David P. Valley's Avatar
I've performed several flat roof IR scans...
http://www.massinfrared.com/?D=77
Old 10/20/09, 8:34 AM
Drill the core and have a qualified roofer with you to patch the sample area.
Larry Kage, CMI
231 929 3525
Old 10/20/09, 10:45 AM
Jason Kaylor Jason Kaylor is offline
Send a message via Yahoo to jkaylor
James,
I would also recommend having a separate company come in and do nuclear to not only back up your findings, but to also do their inspection.
And although manufactures tell you different, I wouldn't do a flat roof inspection without a short wave imager. David’s link above gives a good example of why short wave is better. The first IR image on that page shows an image where the thermographier is elevated. The person that took that image was trying to reduce reflection by elevating themselves, this is not always possible. Because of the angle of attack on a flat roof and the roofing materials (normally designed to reflect light) flat roof inspections generally produce a lot of reflection.
A good back ground in roofing materials, structures and construction would also be highly recommended. As Mario said, you really should be working very closely with a roofing contractor that has the ability to do core samples.
A few other points. Its not a good idea to walk and scan at the same time. NEVER walk backwards! If you are going to use lighting (flat roofs are generally done at night), make sure they do not generate heat on to the roofing surface. Genreally LED lights work best. Always do a flat roof inspection with someone else present (safety). Check all your fall protection requirements for the job and your area. Fall protection can be a pain, and often times expensive to use if the roof isn't set up for it, USE IT! If you have any questions on personal fall protection and fall arrest systems feel free to email or call me.
JJ
Old 10/20/09, 6:48 PM
Jason,
Do you have any idea what the nuclear detectors are worth? I'm assuming some training is involved. Have you used one?
BTW Here in Canada we would probably have to label our vehicle with placards identifying it as “Radioactive” as I’m sure you would in the US. I have to educate consumers/clients about IR as it is. For some reason some clients ask if my thermal imager emits radiation!
Can you imagine if they see the placards on the sides of my van!
Tel.# 416-722-6132
Orange County Home Inspections whandley California Inspectors 12 5/18/11 6:35 AM
Jacksonville, Florida Home Inspections Mike Jewett Ancillary Inspection Services & Additional Topics 0 5/29/09 5:21 PM
Roof deck question wdecker Exterior Inspections 3 11/17/08 10:17 PM
Roof Inspections? dduffy Miscellaneous Discussion for Inspectors 25 8/22/08 12:30 PM
