Hello all, I have some problems with my Flir B50. About a month ago after charging unit I unplugged it and the plug symbol remained on screen yet camera still operated.
Yesterday I went to shoot a panel and I got a 'Disk full' error on screen. There are no pictures on camera and it had an SD card installed. Removed SD card and same came up. Plugged unit to PC and there were no images. I do need to calibrate camera. My question..is there any service areas for camera besides Flir? Thanks! |
| Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Mine did the same thing , i had to send it to flir and have a software updated . How ever mine was a 2006
Why are you trying to find some place other than FLIR? The $200/hr, minimum of 2/hr service charge making you look for cheaper options?
Seems like anything to do with FLIR software glitches should be a minimal service charge given that they don't take much to fix and it's a camera problem, not a misuse problem. How long has it been since you last had it calibrated? Often times, once a year really isn't necessary. Brandon Clark, Certified Infrared Thermographer, CPI, IAC2, Infrared Certified Email : brandon@IrUtah.com www.IrUtah.com www.pwrck.com www.UtahInfraredInspection.com www.OgdenUtahHomeInspection.com www.SaltLakeCityInspection.com |
cost me 850 Brandon which included maintenance
Sounds like a firmware problem only FLIR can repair. Got a Fluke? Only Fluke can repair it.
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
Patrick McDonough is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi Jonathan,
Please give us a call at 1-866-FLIR-911 Option 2 if you still need help with your B50 camera. We would be happy to assist. |
My Flir is about the same age..it does need to be calibrated as well though..What did the service run and what was the turn around time?
I planned on doing so tomorrow...Talk soon! |
| How Many Errors Can You Find...? | jbushart | Thermal Imaging, Infrared Cameras & Energy Audits | 14 | 2/9/11 2:31 PM |
| Hard board siding? | sfalvey | Exterior Inspections | 23 | 11/29/10 2:41 PM |
| National Foreclosure Problems | gfarnsworth | Miscellaneous Discussion for Inspectors | 11 | 10/8/10 5:56 PM |
| Liability question | jcahill | Legislation, Licensing & Legal Issues for Inspectors | 30 | 8/24/08 4:10 PM |
