Old 12/13/09, 2:42 PM
David A. Andersen's Avatar
Default Flir battery charger ?
I have this battery charging system for my Flir BX 320.
The other day I had trouble will one of my batteries not accepting a charge.
In one of my Flir classes this issue was mentioned and a solution was discussed. I can't seem to remember what was said because I did not have this type of camera then.
Can anyone recall hearing anything about this or have a solution to this problem.
The battery charges up to the last flashing indicator but does not complete the charge and the battery does not operate in the camera.
I let the batteries set for a couple of days and I just plugged it in the charger and it is beginning a charge cycle which indicates there was absolutely no charge on the battery.
We will see how this progresses.
This is the same type of charging system for all cameras except for the BCAM type cameras.
BPI# 5015804
Find an InterNACHI certified California Home Inspector (and anywhere else in North America)
Old 12/13/09, 10:44 PM
Chuck Evans's Avatar
Default Re: Flir battery charger ?
Haven't heard of the issue. Have you tried charging it directly in the camera rather than through the charging base?
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 12/13/09, 10:52 PM
Shawn Rowe's Avatar
Shawn Rowe Shawn Rowe is offline
Battery is most likely bad. You will need to replace. This happened to me once when I ran the battery down. Battery was dead... I think I bought a spare through professional equipment.com
Shawn Rowe, CMI
HomeFirst Inspection Services, LLC
- InfraRed Specialist (Level 1 & Building Science certified)
- Code Certified Residential Building Inspector
- Certified Master Inspector
-- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties --
Old 12/14/09, 12:44 AM
rbibler rbibler is offline
Please Note: rbibler is a non-member guest and is in no way affiliated with InterNACHI or its members.
I think Shawn is correct "Battery is most likely bad "
I have a battery in my FLIR B2 That gets mix up with my BX320 Same battery. one of them is bad. I need to get that one replaced.
Best
Ron
Old 12/14/09, 7:42 AM
I tried using the camera. The light just flashes like the charger, on the last light (indicator).
Yes, I'm sure your right. The battery is toast.
It was working fine but just would not "talk" to the camera and will not take a charge.
Charlie B. lost a battery the same way I think.
A Flir Tech came to our Building Science class and I think he said something about the battery. I just can't remember what he said. He told us a lot about the cameras and batteries. Or it may have been Bob Rodgers...
I'll give them a call today when I'm on the road.
Thanks guys.
BPI# 5015804
Old 12/15/09, 10:46 AM
Jason Kaylor Jason Kaylor is offline
Send a message via Yahoo to jkaylor
They still let you drive and talk on ya cell in TN?
JJ
Old 12/15/09, 9:26 PM
Anyone need a BX320 battery? P/N: 1195106-05
I found a good deal ($165 vs. >$250) on them.
Anyone know of a better price? It's a true 2.1Ah vs 1.7Ah capacity.
Had to hunt for hours. The company called me back to confirm within the hour. Seems to have good service policy.
BPI# 5015804
Old 12/16/09, 8:47 AM
David P. Valley's Avatar
David,
Just for my knowledge.....How long did this (now) dead battery last you and how frequently did you use it?
Old 12/16/09, 10:25 AM
About Year and a half.
Used about 3 days a week.
After talking with Flir, I think I ran down the battery and did not charge it for about 4 days (over the weekend) and it was in the very cold during that time. I forgot about it.
It was working fine. Long life, short re-charge. It just wouldn't do anything when I turned the camera back on to check the battery charge.
Flir says that the camera never really shuts off and will use the battery if left in the camera. Full discharge will damage the circuit board in the battery.
There is a 10 yr battery inside the camera to save settings.
If you start your camera and it defaults to B&W (when it was not last used in that pallet) that is an indication of internal battery fault.
The information I was looking for here was about older versions of this battery (-02 , -03).
So if you see the "low battery" indicator, remove it from the camera ASAP even if you can't re-charge it right away.
BPI# 5015804
Old 12/17/09, 1:17 PM
I always remove my battery upon placing it back into the carrying case.
I always charge them after each use and I never allow them to lose their charge fully.
Another thing I do is I swap the battery at every use. I never use the same battery twice in a row.
In the freezing cold, my camera is always with me in conditioned areas.
So far I've gotten almost three years out of the original batteries.
Old 1/4/10, 5:01 PM
Chuck Lambert Chuck Lambert is offline
Unmoderated Guest
Please Note: Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
For those of you who have a dead FLIR battery or two ...Just curious how much do you want for one?
Please let me know.
Chuck
Old 1/4/10, 5:21 PM
Please let me know.
Chuck
Chuck,
Buy new. Used batteries have no guarantee.
If you can afford an IR camera, you can afford a couple hundred dollars for a new battery.
Old 1/4/10, 6:24 PM
Unmoderated Guest
I need the battery to do some experimenting with, not to use in my or any other camera.
Chuck
PS Need one ASAP.
Old 1/5/10, 12:23 PM
I was always under the understanding that you should let your battery run all the way down before a recharge. this ways the battery will not set a false base. ?
Best
Ron
Old 1/5/10, 8:06 PM
Unmoderated Guest
Best
Ron
That is with NiCd batteries only. The ones FLIR uses are Li Ion ..no memory.
Still in need of that dead FLIR battery , someone has to have one they want to get rid of!!!
Chuck
Standard Li/Ion battery for the ThermCAM® E Series. Ron C. Bibler Thermal Imaging, Infrared Cameras & Energy Audits 2 9/25/08 6:13 PM
Flir offers FREE infrared conferences dplummer Thermal Imaging, Infrared Cameras & Energy Audits 5 3/16/08 11:48 AM
Battery Recall - Milwaukee Electric Tool Co. pabernathy Electrical Inspections 3 7/12/07 10:08 AM
DeLL BATTERY RECALL ksitzes General Inspection Discussion 2 8/15/06 4:49 PM
