Old 6/8/10, 9:53 AM
pmassie's Avatar
pmassie pmassie is offline
Please Note: pmassie is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Flir I7
Any thought on the Flir i7 ??
Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/8/10, 3:50 PM
Jason Kaylor Jason Kaylor is offline
Send a message via Yahoo to jkaylor
Default Re: Flir I7
120x120 resolution, .1C at 25C (100mk / 100 NETD) thermal sensitivity and 3.71 MRAD. The thermal sensitivity and MRAD do not meet the proposed Resnet IR standard.
The screen is small. It is an okay camera if you are just doing electrical inspections and maybe light industrial.
Jason Kaylor – JJ
VP of Specialty Products
877/207-1244
AC Tool Supply
Weatherization Contractor
Alnor ABT701
TSI Hood
UEI C75
Old 6/9/10, 11:25 AM
David A. Andersen's Avatar
Default Re: Flir I7
What do you plan to use it for?
Every camera out there has a purpose. The opinions floating around out there that home inspection usage for thermal imaging does not require high-resolution cameras is a bunch of baloney!
You are required to show up for a home inspection at a determined time (this may not coincide with the best conditions for scanning). You're not flexible as you would be if you were doing a roof scan or an energy audit for the property owner.
When you're required to push temperature differential, vapor pressure differential and wet bulb/dry bulb differential, low-end cameras don't cut it.
Using thermal imaging is to speed up the inspection process and detect latent conditions that are not seen with the naked eye. Documentation of the condition is the second use. Low-resolution for documentation provides poor quality. A blue shadow versus a defined shape makes the difference between determining air versus moisture intrusion.
You should always back up your thermal scans with other equipment like moisture meters, however a highly sensitive thermal camera can detect moisture inside the wall that is not detectable with a moisture meter as moisture diffusion on the exterior of the wall is not the same as inside insulation (which thermal camera can measure).
There are thousands of other applications that you can use a low-end camera on, just don't think you can "do it all" as so many camera owners depict on their websites.
BPI# 5015804
Flir B-200 for Sale jmckellar1 Thermal Imaging, Infrared Cameras & Energy Audits 3 4/19/10 11:05 PM
Awesome deal on FLUKE and FLIR cameras, training and blower doors from AC Tool Supply gromicko Thermal Imaging, Infrared Cameras & Energy Audits 21 4/1/09 11:24 PM
Flir B-50/60 dbowers Thermal Imaging, Infrared Cameras & Energy Audits 21 12/30/08 9:41 PM
Flir offers FREE infrared conferences dplummer Thermal Imaging, Infrared Cameras & Energy Audits 5 3/16/08 11:48 AM
Is FLIR infared imaging the future wave of Home Inspections? jwatts1 General Inspection Discussion 66 5/1/07 5:48 PM
