Old 8/11/11, 5:52 AM
Rye Zers Rye Zers is offline
Please Note: Rye Zers is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default FLIR i7 question
I have heard description of this unit that describes many times the image freezes on the screen and it retains a shadow even if the camera was sweeping at 30 degree angles non stop.
Is this a normal occurence or is the unit defective? I’m particularly concerned because I haven’t seen a FLIR i7 before and wanted to buy one for general use and I don’t want it to pause every now and then.
Is the reason for the pause because the temperature scale is adjusting? Does it do this every few degrees of turns?
What kind of thermal imager that don't do this constant pausing? I don't think it has to do with 9Hz because the pause is a second long or so. Thanks.
Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/11/11, 9:33 AM
David A. Andersen's Avatar
Default Re: FLIR i7 question
All cameras do that. Some more than others.
This is to correct for drift.
If the camera does not do it, it will drift right off the scale.
Turn the camera on for several minutes before you want to use it and don't shut it off till your done. Also leave the lens cap open.
Adverse temps indoors/out will make this happen more.
Bring in the camera and leave it out of the case till you need it.
BPI# 5015804
Old 8/11/11, 10:12 AM
What do you mean "it will drift right off the scale"? I think it's auto adjusting the temperature range and unit with faster processor or graphics can re adjust faster, right? This means if I "lock" the screen or temperature, it won't pause anymore.
Besides inspecting electrical. I want to use it too at night in quick scan of the outside of my house to scan for animals hiding in bushes. And I don't want it to pause while scanning. Maybe by "locking" the tempeture, it will avoid the pause and temperature rescaling?
Old 8/11/11, 11:31 AM
Linas Dapkus's Avatar
Linas Dapkus Linas Dapkus is offline
Do you own an I-7 Dave? I heard that sure is a mighty fine piece of equipment.
Old 8/11/11, 3:25 PM
I'm sorry Sir, I have never held one and I am just doing the best I can with the information provided...
Rye; to understand what I am talking about may take some continuing education that I am not prepaired to attempt to convey in a short message board post.
If you do not understand "Drift" I recommend that you take the required courses before you pruchase or use any thermal imaging device so you don't wast money and go off "half-cocked" on some adventure...
Or just ask John, he can square you away.
BPI# 5015804
Old 8/11/11, 6:33 PM
I know all about blackbody radiation and emissivity. Anyway. Thermal drift is defined as "Drift caused by internal heating of equipment during normal operation or by changes in external ambient temperature".
With regards to the screen pausing every often. I think what its doing is auto adjusting the temperature scale depending on target. For example. When you point the imager at a scene with temperature between 15 to 50 Celsius. The screen will show that scale. If you then point it to higher temperature. It will pause as the screen updates and turns the scale to 15 to 120 Celsius. I think this is the reason for the screen pause. I wonder if the unit microprocessor speed is related to how fast it updates. To those who own the FLIR i7. How does it perform compare to others? I plan to order it as soon as I get this info. Thanks.
Old 8/11/11, 6:46 PM
Chuck Evans's Avatar
Research NUC or Non-Uniformity Correction and trust Dave's word that it is a normal and essential function of the imager.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 8/12/11, 4:34 AM
I went to a FLIR i7 demo center and went to work with it. Temperature scale changes don't make the screen pause. So it is the Non-Uniformity Correction that causing the pauses. Now for those who own higher end models. Is there a way to temporary disable the feature in situation that you need fast motion and can take a slight decrease in temperature accuracy (such as mobile based thermal imager like the PathFinder car system or military vehicle thermal system)? Just curious as I know the FLIR i7 won't make you disable it.
Old 8/12/11, 12:35 PM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
First off...you are not going to get any kind of advanced features like that from a low end camera. If you want live video that does not get interrupted, that is not something that modern handheld cameras can do because they are uncooled microbolometers. You would need to think about going into the cooled focal plane array camera world or into a surveillance system type camera.
No one camera is going to be able to perform all tasks, especially lower end entry level cameras. You are basically trying to make a hammer perform as a calculator.
Pick which application you want to do and find the appropriate camera to do the job.
Old 8/12/11, 1:57 PM
John McKenna's Avatar
John McKenna John McKenna is offline
Exactly.
Executive Director - Master Inspector Certification Board
25 Yrs Constr Exp - 13 Yrs Home Inspector Exp
American Home Inspection - East Texas.
Flir B50 errors and problems jmeeker Thermal Imaging, Infrared Cameras & Energy Audits 9 7/19/11 11:30 PM
Sump Pit/Pump Question Joey D'Adamo Plumbing Inspections 4 11/26/08 1:04 PM
Is FLIR infared imaging the future wave of Home Inspections? jwatts1 General Inspection Discussion 66 5/1/07 5:48 PM
