Old 2/26/09, 4:37 PM
Nick Gromicko's Avatar
Default FLIR sued HomeSafe. Read the lawsuit.
http://www.nachi.org/documents/flir-...fe-lawsuit.pdf
Find a Home Inspector
Old 2/26/09, 4:45 PM
Michael R. Boyett's Avatar
Default Re: FLIR sues HomeSafe. Read the lawsuit.
That's a 4 year old lawsuit...surely it has been settled by now but then again, the wheels of justice turn slowly.
Excellence in Inspections
Mike Boyett, TREC #7290
mikeb@capcityinspections.com
Capital City Inspections
Austin, Texas
(512) 577-2579
Is this 3 1/2 years old?
Larry Kage, CMI
231 929 3525
Old 2/26/09, 4:48 PM
John McKenna's Avatar
John McKenna John McKenna is offline
YES..!
Executive Director - Master Inspector Certification Board
25 Yrs Constr Exp - 13 Yrs Home Inspector Exp
American Home Inspection - East Texas.
Old 2/26/09, 5:36 PM
kweiss's Avatar
kweiss kweiss is offline
Anyone know the result of this? Has it been settled or ruled on?
Kevin Weiss
Level I Infrared
www.AbsoluteInspections.net
www.homeinspectorsplanotx.com
www.homeinspectorsmckinney.com
Absolute Inspections, LLC
972-463-0887
Old 2/26/09, 5:37 PM
Jack R. Robnett Jack R. Robnett is offline
HomeSafe's Approved Patents Include:
Patent No. 7,369,955 (22 Claims Approved) – Method for Residential Indoor Environmental Quality Inspection and Monitoring: This patent covers the usage of an infrared camera to locate any thermal anomaly – including but not limited to an uncontrolled or hidden water intrusion – followed by obtaining data relating to indoor air quality, including visual confirmation of mold, collection of a mold sample, measurement of relative humidity, installation of a constant air/gas monitor system and/or other related measurements. A thermal anomaly is an unexplained difference in temperature from one area of a home to another, often indicating a problem that can’t be detected by ordinary means. Thermal anomalies signify a problem with faulty wiring, hidden moisture, missing insulation, heat/energy loss, termite infestations and more.
Patent No. 7,445,377 (7 Claims Approved) - Non-Destructive Residential Inspection Method and Apparatus: This patent covers HomeSafe’s method for creating a “thermal window” – that is, preparing a home for an infrared inspection by creating a temperature differential between the inside and the outside of the home, followed by obtaining temperature profiles of the home’s interior components and exterior components. These temperature profiles are then analyzed to uncover thermal anomalies indicating problems relating to (including but not limited to) structure, moisture or electrical issues.
Patent No. 7,385,483 (13 Claims Approved) - Infrared / Acoustic Method to Detect Termite Infestations in a Structure: This patent covers HomeSafe’s four-step procedure for uncovering termite activity in a building, including: 1) a traditional visual inspection; 2) infrared detection of hidden moisture that may indicate the presence of termites; 3) usage of a moisture meter to confirm the presence of moisture in the “suspicious” area identified by infrared; and 4) usage of HomeSafe’s acoustic sensor to detect the unique sound patterns of termites in the “suspicious” area and usage of HomeSafe’s pattern recognition software to analyze and confirm termite signals on the spot.
Patent No. 7,271,706 (13 Claims Approved) - Termite Acoustic Detection Device: This patent covers our acoustic termite detection device which uses acoustic sensors to hear termite sounds beyond the range of human hearing. Paired with an infrared thermal imaging camera to find hidden moisture associated with termite infestations, the acoustic device pinpoints the exact location of a termite nest.
Patent No. 7,434,990 (13 Claims Approved) - Additional Methods to Detect Termite Infestation in a Structure: This patent covers the usage of infrared scanning to detect moisture associated with termite infestations followed by additional methods, including a microwave motion detector, an X-ray detector, a gas detector or termite-sniffing dogs, to confirm the presence of termites.
Patent No. 7,429,928 (4 Claims Approved) - Method to Prevent Termite Infestations by Modifying Termite Behavior:This patent covers HomeSafe’s method to prevent termite infestations in a home by generating very low-amplitude acoustical vibrations within the home’s interior walls. These vibrations, which are inaudible to the human ear, disturb and repel termites and drive them out of the home. The specific vibrations have a custom-selected frequency and amplitude experimentally proven to be highly effective at modifying termite behavior.
Patents Pending:
In addition, three other patent applications are under review by the USPTO. Two of them relate to home inspections and the third is related to termite inspections. Their application numbers are as follows: 12/194,977; 12/209,590; and 11/893,204. Descriptions of these will be provided once approval of the various claims is provided by the USPTO.
ALL HOME INSPECTION PRICES INCLUDE INFRARED SCAN
BUYER INSPECTION
< 1,000 sq. ft.
$275
1,001-2,000 sq. ft.
$325
2,001-3,000 sq. ft.
$375
3,001-4,000 sq. ft.
$425
4,001-5,000 sq. ft.
$475
> 5,000 sq. ft.
Call For Quote
NOTE: Add $50 if a crawlspace is present or if home is a foreclosure.
Old 2/26/09, 5:45 PM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
Default Re: FLIR sued HomeSafe. Read the lawsuit.
Sniff this, HomeSafe...
Old 2/26/09, 8:55 PM
Erby Crofutt's Avatar
Erby Crofutt Erby Crofutt is offline
So, who knows what the result of the suit is.
On a side note, I get a kick out of this on the staff page of their website.
Director of Inspection Training
For eight years, xxxx xxxxxxxx served on the administrative staff at a public housing authority. In this capacity he performed duties as Administrative Assistant, Computer Specialist, and Occupancy Specialist. Prior to that, he owned and operated a computer retail store. He has also worked as a computer programmer for Security Savings and Loan and has owned his own computer-consulting firm.
A computer geek as Director of Inspection Training!
Old 2/26/09, 9:23 PM
Didn't that same resume just get someone elected president?
Austin, Texas
(512) 577-2579
Old 3/1/09, 9:31 AM
mthomas2 mthomas2 is offline
Lot's pf people believe that the HomeSafe threats are a joke.
While it may be unlikely Homesafe will go after end users (more likely, they hope that manufacturers' of IR equipment will decide it's cheaper to pay them a license fee than litigate) as I understand it if they chose to do so - which world be one way to pressure manufacturers - defense would be very expensive for an individual sued.
Homesafe has lately been saying the following:
"What we do require is that home inspectors and pest companies that are utilizing IR in their business make sure that they are not utilizing our patented processes. We also encourage inspectors that are utilizing IR to consult with patent attorneys and review in detail the patent claims to make sure they are not infringing on the patents."
http://www.infrared-training.com/com...s/thread/7152/
Obviously, such consultation and development of a protocol to avoid infringement would be a substantial expense on an individual basis. The same is even more true of an attempt to invalidate or radically narrow the scope of the patents on ground of "prior art" or for other reasons - this effort instead a is a natural undertaking for a trade group or professional association.
Over the years NACHI has spent a a considerable amount of membership dues on litigation - much of in my opinion while it may have been beneficial to NACHI as a for-profit organization but has been of marginal direct benefit to membership.
IMO NACHI's response to Homesafe - which given it's requested licensing fees and the cost of defense if individual inspectors are sued is potentially a substantial economic burden on the home inspection industry - is a good test of whether the membership dues I've paid for the last few years will actually be deployed in direct support of the memberships' interests.
Old 3/1/09, 6:36 PM
kweiss's Avatar
I asked the same question directly when this issue first hit the boards. The initial response I received from INACHI was they did not see this as a threat to members. I believe the quote was something along the lines of "tell me who has been harmed." That a proactive approach, such as you describe was not warranted. I disagree, but at that point decided not to count on INACHI for any help in this issue.
If something has changed with that opinion/position, I would be very interested to hear what it is, although a more private communication method than a public forum would be more appropriate.
Kevin Weiss
Level I Infrared
972-463-0887
Old 2/6/11, 10:26 AM
Hubert A. Miles Hubert A. Miles is offline
I would also like some information on the settlement of this issue from FLIR. I just recieved a certified letter from HomeSafe and it seems they are targeting individual inspectors
Old 2/6/11, 9:34 PM
Individual inspectors have always been their primary target. Hard to believe they're still trying to pull this crap. Is your letter the same as the one attached to the PDF of the lawsuit?
Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/6/11, 9:53 PM
Joseph Hagarty,  CMI's Avatar
I was using a Flir camera (in a petrochemical environment) long before HomeSafe became a Business..
The camera is a tool...
.... which is older than HomeSafe...
The times that I have used one, are based upon the training I recieved long before HomeSafe became a business entity...
Ridiculous....
Like Maglite patenting the use of Flashlights to Law Enforcement and
suing every home inspector that buys or uses one.... Hello????
LOL
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 2/6/11, 10:03 PM
http://www.pestfree.com/meet-brandon/
My brother has been working with this company since its inception (over 15 years)
Brandon
was the first termite dog that i was aware of back then....
I had investigated training of a dog (shorthair pointer) over 8 years ago. Cost was projected at $10,000 plus...
Ironic that homesafe claims they invented the technology 5 years ago
Joseph P. Hagarty
Phone: 610-399-3675
Extech I5 jhittle Thermal Imaging, Infrared Cameras & Energy Audits 71 2/19/09 6:55 PM
FLIR reply to HomeSafe patent issue. gromicko Thermal Imaging, Infrared Cameras & Energy Audits 2 1/19/09 6:45 PM
Flir offers FREE infrared conferences dplummer Thermal Imaging, Infrared Cameras & Energy Audits 5 3/16/08 11:48 AM
