I use the high contrast rainbow for most of my images because they are easiest for clients to understand and look good on the report(my opinion). I've noticed my FLUKE having a hard time providing a really clear image without alot of frequency noise in many conditions.
If I'm using high contrast and point towards the oven coils, stove burners, furnace burners or anything really hot than my image becomes so static filled that I can't even get the shot. I often find myself pointing the camera away to adjust the image than pointing it back and immediately capturing the image before the image becomes to static filled. I realize you sacrifice some image clarity when you opt for a 60hz camera but I'm wondering if this is a FLUKE issue, or just my camera, or if all the 60hz cameras give off these static filled images? I find this to be quite irritating and sorta feel like the camera shouldn't be 60hz if it can't keep up in providing a clean image. Has anybody found any specific settings that help relieve some of the image noise? I'm still very satisfied with the FLUKE Ti-32 and have no regrets in buying it but It would surely be alot nicer without the static. Brandon Clark, Certified Infrared Thermographer, CPI, IAC2, Infrared Certified Email : brandon@IrUtah.com www.IrUtah.com www.pwrck.com www.UtahInfraredInspection.com www.OgdenUtahHomeInspection.com www.SaltLakeCityInspection.com |
| Need a home inspection in Mississippi? Check out InterNACHI's listing of Mississippi certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Do you have the camera set in manual or auto?
Russell Inspection Services New Hampshire state license # 57 Level I Thermographer, ITC Certified Building Science Thermographer, ITC Certified Building Analyst, BPI Certified Commercial Inspector, ITA Certified Septic Evaluator, GSDI #148 www.newenglandthermalimaging.com www.russellinspectionservices.com www.nhsepticinspection.com |
I use both. I'll often keep it in manual and constantly hit the adjust button when I'm doing stuff outdoors or where there's lots of temp. variations.
Keeping it in manual helps but it isn't the solution. Brandon Clark, Certified Infrared Thermographer, CPI, IAC2, Infrared Certified Email : brandon@IrUtah.com www.IrUtah.com www.pwrck.com www.UtahInfraredInspection.com www.OgdenUtahHomeInspection.com www.SaltLakeCityInspection.com |
I am not following you are you talking about saturation on your images Static is not in my vocabulary I don't think your camera is rated for the high temps of a furnace burner or electric heat element the image will go into saturation immediately perhaps were not on the same page
Brandon,
Could you please post an image that you believe is "static" filled. It would help us in helping you. |
I'm sorry for not providing the exact term for what I'm trying to say but "grainy" "static filled" "noisy" is the best I can explain it.
My FLIR has never had any "grainyness" to any of the images so I'm trying to figure if it's a FLUKE thing, a 60hz thing, or a my camera only thing? I'm not saying I can't get crystal clear images with the FLUKE, but I just have to change the palette given the conditions. The FLIR never showed any grainy images but then again it wasn't 60hz. These are a couple images I just took of some lights. These images are only in the 400 degree range so it gets alot worse but you should be able to see what I'm talking about. Brandon Clark, Certified Infrared Thermographer, CPI, IAC2, Infrared Certified Email : brandon@IrUtah.com www.IrUtah.com www.pwrck.com www.UtahInfraredInspection.com www.OgdenUtahHomeInspection.com www.SaltLakeCityInspection.com |
The Fluke Ti32 and TiR32 thermal imagers are extremely
sensitive devices that can detect temperature differences ≤50mK (0.05 °C). They allow minimum spans as low as 2 °C in many operating modes. Special palettes and palette modes are also offered in order to enhance and highlight very small thermal differences in a scene. In addition, optional telephoto and wide angle lenses are available to further enhance the anomaly detecting capability of the imagers. Every effort is undertaken to produce a high quality, and radiometrically accurate infrared image under as many circumstances as possible. However, there are often extreme use situations under which the infrared energy being emitted from a target of interest is so small that the imager reaches the limits of the physical (physics) properties, which govern its operation. Using the imager under these circumstances, can at times result in the appearance of light rings or a halo on the infrared image. This is completely normal. Although it is possible for Fluke to mitigate these artifacts by artificially adding electronic noise and additional processing to the infrared signal, we have chosen not to do so in order to preserve the extreme sensitivity of the instrument. If any of these artifacts do appear in your properly focused infrared image, please be assured that it is only because there is not enough of a thermal differential in the scene to indicate the presence of an anomaly or issue. (In essence, the imager is so sensitive, that it is “seeing itself” optically, radiometrically, and electronically.) Typically, increasing span, changing color palette, or introducing a thermal differential into the scene will eliminate the appearance of any artifacts, and will still allow the appropriate interpretation of the infrared image. All thermal imagers require appropriate warm-up time in order to obtain the most accurate temperature measurement and best image quality. This time can often vary by model and by environmental conditions. Although most imagers are fully warmed-up within 3-5 minutes, it is always a best practice to wait at least 10 minutes if the most accurate temperature measurement is critical to your application. Whenever changing or adding optional lenses, additional stabilization time may be required depending on the situation. BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
Brandon why dont you use a different pallette and adjust it to pull out what you want, like a stain for example.
Quit whining about your camera. I messed with Waynes tir32 last night and that thing spanks mine away.. Amazing clarity. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
I'm not really "whining" about my camera. Like I said, I'd buy another one had I to do it over again. I'm just inquiring about a concern that some others may or may not be experiencing. Brandon Clark, Certified Infrared Thermographer, CPI, IAC2, Infrared Certified Email : brandon@IrUtah.com www.IrUtah.com www.pwrck.com www.UtahInfraredInspection.com www.OgdenUtahHomeInspection.com www.SaltLakeCityInspection.com |
The Ti32 can handle the temp as it is rated for up to around 1200 degrees F. I have used my Ti32 for some extreme temps and not had any problems. You do have to watch for the camera calibrating itself continuously and you may be having a problem with the oven temperature variations. Opening an oven that is reading 400 degrees takes seconds for the temperature to start dropping. The next time I am in a home without my customers hanging on my back I will break out my Ti and see what happens.
Chuck Forman CPI Forman Inspection Services Denver, Colorado 720-641-9518 Office 720-988-3387 Direct 866-908-6872 Fax http://www.formaninspectionservices.com http://www.formaninspections.com http://denvercoloradohomeinspections.com http://coloradocommercialinspections.com Email: chuck@formaninspections.com Serving all of the Denver Metro Area! If you shoot straight and tell it like it is, you will never have to worry over what you lied about yesterday.... John Wayne |
Brandon,
At what temperature does it start at? Forgive me if this is a no-brainer question but what is your range set at for these images? I am not that familiar with the Fluke Ti32 but I can change ranges on my Flir T400 |
Hey Jeff, The temp range doesn't have to be adjusted on the TI32. It's good from 0 up to 1200 degrees. As you can see in the images above, one of the really grainy images is from a light only putting off 200+ degrees. I'm a bit surprised or actually very surprised that nobody really has a clue what I'm talking about. I understand all the science behind what causes certain things such as the rings and even what can cause a loss in image quality when using a 60hz camera. I appreciate those who have in-fact tried to help but I wasn't really seeking scientific explanations or text book answers of what can cause loss of clarity in thermal imaging as a whole. I'm aware of what the possible causes are. I was hoping to get some input from some folks who have some experience using the TI32 and who also have experience using other brands of cameras in the same class so I could determine - once again - "Is it a FLUKE thing, a 60 hz thing, or a my particular camera thing?" If someone buys the TI32 for their first camera or has a lower res. FLUKE camera than of course the image clarity of the TI32 is going to seem awesome. The TI32 does provide an awesome image. I'm simply stating that I deal with alot of grainy images and the need for palette changes with the FLUKE that I never experienced with the FLIR B400. Oh well! I wasn't trying to step on anybodies toes or come across like I was whining about my camera or complaining about FLUKE. I'm a big fan of what FLUKE offers. I just wanted to know if any folks had bought the TI32 and noticed any of the grainy images as compared to their previous camera(of the same class). I could pick up a new FLIR and be able to tell you within 90 seconds if the images act the same way as my FLUKE. I don't have a new FLIR. I didn't see the harm in discussing the concern and asking if any others had similar concerns. I guess I'll figure it out soon enough when I get the opportunity to try out one of the new FLIR's. Jeff, sorry for posting all this in your message quote. Anything after the 2 answers to your questions weren't really directed towards you so please don't take it that way. I realize your trying to help and I appreciate it. Brandon Clark, Certified Infrared Thermographer, CPI, IAC2, Infrared Certified Email : brandon@IrUtah.com www.IrUtah.com www.pwrck.com www.UtahInfraredInspection.com www.OgdenUtahHomeInspection.com www.SaltLakeCityInspection.com |
I just got a the 32 i will try a oven this am and let you know Brandon
Basically I'm interested in seeing if your rainbow high contrast images look about like the ones I posted. Whatever images you take than I'm going to try and reproduce and see if there's any difference. This would definitely give me alot of the answers I'm curious about. Brandon Clark, Certified Infrared Thermographer, CPI, IAC2, Infrared Certified Email : brandon@IrUtah.com www.IrUtah.com www.pwrck.com www.UtahInfraredInspection.com www.OgdenUtahHomeInspection.com www.SaltLakeCityInspection.com |
| Universal Infrared Thermal Imaging Report Software | sgilligan1 | Thermal Imaging, Infrared Cameras & Energy Audits | 0 | 6/3/11 2:40 PM |
| IR Viewer | jmckenna1 | Thermal Imaging, Infrared Cameras & Energy Audits | 32 | 12/20/09 6:03 AM |
| Fluke Ti32 / Fluke TiR32 & Level X Infrared Certification Package | jkaylor | Thermal Imaging, Infrared Cameras & Energy Audits | 6 | 9/10/09 7:37 PM |
| Has Your Fluke Digital Meter Been Recalled? | jbushart | Electrical Inspections | 1 | 5/16/09 9:21 AM |
