On todays inspection My camera would not focus. I changed the palette to black and white and it didn't make any difference. Anyone else experience this with the Fluke? The camera is about 10 months old.
Gary,
I'm sure you tried this but in case you didn't.. Remove battery for a few minutes, reinstall and try and reboot. Andrew MacDonald MacDonaldPropertyInspections.com InsightThermalDiagnostics.com ITC/FLIR Certified Building Science Thermographer ITC/FLIR Certified Level 1 Thermographer |
Gary,
Were you in a poor delta T environment? John McKenna, CMI (TREC #4565)
Yes, on the last two inspections when this problem first showed up, indoor and outdoor temps were the same. Does that have an adverse affect on focusing?
Time for some training.
As Linas stated, training will help.
A minimal delta T makes it harder to focus. Changing palettes like you did can help, going in to picture in picture mode can also help because it will give you a point of reference. Span and back ground temp can also help. Training will help you hone your skills with all of those features. John has really good training focused towards home inspections. Infraspection, Snell and FLIR ICT are all great level I programs. I know a lot of guys that are super busy and just do not have the time to take off for training. I believe McKenna's training can be done online and I know Infraspection offers a distant learning program for the level I and II certs. Jason Kaylor – JJ VP of Sales 877/207-1244 AC Tool Supply Fluke Thermal Imagers FLIR Thermal Imagers HotShot Hi-Rez Infrared Cameras Fluke TiR1 Resources FLIR B60 Resources Retrotec Duct & Blower Door Last edited by jkaylor; 3/8/09 at 12:08 PM.. |
Kevin Luce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Jason, I know that you are a sales person but do you go out in the field to do IR inspection on a weekly basis?
Just wondering. |
Poor thermal days will produce washed out unfocused images. Good reason to hate spring and fall.
I have noticed that this is more noticeable with lower resolution cameras. It usually isn't unworkable, but it makes the scan much harder to perform. Professional Inspector Level I Infrared www.AbsoluteInspections.net www.homeinspectorsplanotx.com www.homeinspectorsmckinney.com Absolute Inspections, LLC 972-463-0887 |
Jeff Moore is a non-member guest and is in no way affiliated with InterNACHI or its members.
It's not that you are not able to focus with a small delta t but that without thermal differences it is difficult to tell if focus is right.
Thats where thermal tuning of the image is important and may necessitate palatte change. Remember that without a difference between outside and inside temps a good thermal review of the home is extremely difficult. imho |
the temperature difference in various materials is very distinct. When the indoor and outdoor temperature are all the same, then many of the materials start to fog together as one temperature. We call this a low delta T environment and it makes the image look very poor. The two cups below are very easy to see (and focus) because they have such differences in temperature (high delta T). The stairs disappear in the IR image because of lack of temperature difference. Call me if I can help, 888-818-4838
Executive Director - Master Inspector Certification Board 25 Yrs Constr Exp - 13 Yrs Home Inspector Exp American Home Inspection - East Texas. Last edited by jmckenna1; 3/8/09 at 2:27 PM.. |
OJ Utter is a non-member guest and is in no way affiliated with InterNACHI or its members.
Gary-
One trick that helps with focus is changing to "black and white" color pallette. Also if you are looking at something like a wall with little thermal difference go put your hand on the wall for about 5 seconds. That gives you something to set your focus off of. But then you need to remember that when you change your distance your focus needs to change. OJ Utter www.utterprecision.com |
As always, thanks to all for the great info. I plan on getting the training but I want a bit more hands on with the camera first. (and a bit more money)
When you focus a regular camera, you are relying on light intensity (and, to a certain extent, color) differences. If you try to focus a regular camera on a plain white wall, it is very hard. If you try to focus a camera in a dark room, it is hard, if not impossible. Same thing with IR, but it is not the differences in light intensity of color, but the difference in temperature that is the problem. I, usually, will not do an image with anything less than a 5 degree (F) delta T. Most people say 10 degrees, minimum. Depends upon your level of expertise and training. Have to set thinks like emisivity, reflectivity, leval and span to get any kind of meaningful image. And, just because the image has something to focus does not mean that the inage in meaningful. It's NOT about the picture, it's all about the information that the image is containing. Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
I have always found B&W to be the easiest to work with for most general applications in a home. Another trick for focusing is to focus on a window blind or HVAC register to gauge your distance focus. I use the hand trick to impress clients and there kids - hadn't really thought of using it for focus, but it would work.
John Snell is a non-member guest and is in no way affiliated with InterNACHI or its members.
In these situations with low thermal contrast, make sure your span is as narrow as possible. Then focus on something—ANYTHING!—with some thermal difference: a handprint, a lightbulb, sun shining on the floor. You need a thermal difference to be able to focus. I would also encourage you to get some of your practice while NOT on the job. Job pressures are too great and make learning difficult (or dangerous!). Sit in your own home or office and try focusing in similar situations until you master the camera. You'll not regret the time invested. When you are ready, I hope you'll also consider more formal training. Thermally yours, John Snell ASNT NDT Thermal/Infrared Level III #48166 Snell Infrared 800-636-9820 802-229-9820 http://www.thesnellgroup.com http://www.IRTalk.com http://www.learnnewsolutions.com/ |
| FLUKE TiR For Sale | dbowers | Thermal Imaging, Infrared Cameras & Energy Audits | 8 | 1/19/09 6:11 AM |
| Toronto Convention now just $99! | gromicko | Canadian Inspectors | 36 | 4/3/07 12:22 PM |
| Fluke Ti20 Thermal Imager now available | jbonelli1 | Ancillary Inspection Services & Additional Topics | 0 | 4/18/06 9:14 PM |
