Old 12/23/09, 7:08 AM
John Evans John Evans is offline
Default Forgot To Connect HVAC Duct
Interesting images of very hot cathedral ceiling with apparent missing register. Owners have been heating the ceiling for 12 years!
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Find an InterNACHI certified Oklahoma Home Inspector (and anywhere else in North America)
Old 12/23/09, 7:43 AM
wsiegel wsiegel is offline
Default Re: Forgot To Connect HVAC Duct
How do you know it just not missing insulation?
Old 12/23/09, 8:51 AM
David A. Andersen's Avatar
Because it's not 105F outdoors this week!?
Could be solar loading but the patterns outside of the rafter bays indicate air movement.
BPI# 5015804
Old 12/23/09, 9:53 AM
32 degree outside temperature with 9" batt insulation at the inaccessable cathedral ceiling. No existing register in large master bathroom, except for one in toilet closet. Apparent 105 degree temperature matched reflected temperature recorded at adjoining bath register.
Old 12/23/09, 10:41 AM
William J. Decker's Avatar
To verify this, I would also look at the roof in this area, either using thermal or just looking for melted snow, if you have snow.
If the underside of the roof decking is warm, most probably a detached duct.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 12/23/09, 12:20 PM
Jason Kaylor Jason Kaylor is offline
Send a message via Yahoo to jkaylor
A good fiber video scope can also be used in areas that are inaccessable. The modern day ones are in the $300 ballpark and can take pictures or even record. They also have their own built in LED light(s) so dark areas are easily accessable for images.
JJ
Old 12/29/09, 1:04 PM
kweiss's Avatar
kweiss kweiss is offline
Doesn't snow much in Texas, Will=) Though we had a white Christmas Eve in Dallas and it is supposed to snow this afternoon. So much for global warming.
I have found that a couple of times. I found it in the summer so the initial image showed cold at the spot when it was hot outside. Then I verify by running the heat. Have a set of images showing the spot going from cold to hot. If I have some time I will try and round them up and post them.
Nice find John.
Kevin Weiss
Professional Inspector
Level I Infrared
www.AbsoluteInspections.net
www.homeinspectorsplanotx.com
www.homeinspectorsmckinney.com
Absolute Inspections, LLC
972-463-0887
Old 12/29/09, 1:10 PM
kweiss's Avatar
Found them.
forgot-connect-heating-venting-air-conditioning-duct-ir002657.jpg   forgot-connect-heating-venting-air-conditioning-duct-ir002658.jpg   forgot-connect-heating-venting-air-conditioning-duct-ir002659.jpg   forgot-connect-heating-venting-air-conditioning-duct-ir002660.jpg   forgot-connect-heating-venting-air-conditioning-duct-ir002661.jpg
Kevin Weiss
Level I Infrared
972-463-0887
Old 12/29/09, 5:06 PM
rbibler rbibler is offline
Please Note: rbibler is a non-member guest and is in no way affiliated with InterNACHI or its members.
Attachment 33978
Attachment 33979
Attachment 33980
Easy way to check your finding john. Run the heater get things hot and then turn on just the blower no heat. If the pattern changes you got your information. Or if you can repeat the pattern over and over.
Best
Ron
HVAC Duct Issue mmerino Inspecting HVAC Systems 9 11/6/09 10:48 PM
What is your HVAC procedure? sstowe Inspecting HVAC Systems 66 5/28/09 12:48 PM
HVAC duct air leaks? Scott Dana Thermal Imaging, Infrared Cameras & Energy Audits 11 12/23/08 11:49 PM
