Jian Zhang is a non-member guest and is in no way affiliated with InterNACHI or its members.
http://www.pat-training.co.uk/irisys...11_thermal.htm
IRISYS IRI 1011 Thermal Infrared Camera
IRISYS Thermal imager camera at a very low price ! The IRISYS IRI 1011 universal thermal imager is an amazing low cost IR imager which brings the benefits of infrared thermal imaging to everyone with a low cost price. This infrared camera from PAT Training Services Limited is ideal for predictive and preventative maintenance using temperature measurements. The IRISYS IRI 1011 connects to a compatible PDA and can be operated one handed using the optional Pistol Grip Handle. All measurements can be downloaded and stored on the optional IRISYS ISI1601 Software. |
Don't know if it's good or not, but that's a thousand pounds UK, not a thousand dollars US. ~ $1670.00 US
John Snell is a non-member guest and is in no way affiliated with InterNACHI or its members.
As I have often suggested here, look at what your real needs are and buy appropriately. Thermally yours, John Snell ASNT NDT Thermal/Infrared Level III #48166 Snell Infrared 800-636-9820 802-229-9820 http://www.thesnellgroup.com http://www.IRTalk.com http://www.learnnewsolutions.com/ |
jbettencourt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Detector 16 x 16, the I5 that most people would say is not a great choice for home inspection is 80 x 80, B-cam 120 x120, TIR 160 x 120. Keep the money and save some more for something that will actually do the job.
Leslie Tack is a non-member guest and is in no way affiliated with InterNACHI or its members.
For Home Inspection applications we are suggesting the IRISYS model, 4010 which I believe is cheaper than the FLIR B-CAM. The 4010 has a 160 X 120 pixel format infrared array. I am preparing a powerpoint on images with the 4010 for home inspection applications. If anyone is interested in obtaining this powerpoint you can email me at Les.Tack@pembrokeinstruments.com. The 4010 is very comprtitively priced against FLIR cameras designed for home inspection.
Is anyone familiar with this company? Any one using one of the Pembrokein models or tried one out? |
Never heard of them. FLIR and Fluke are the only ones mentioned. I did an inspection on a foreclosure yesterday where the Flir BCam came in pretty handy. I told the buyer to make sure the water was turned on because the house had been winterized. The water was turned on an hour prior to inspection. Master bath above the kitchen had a leak.
We are a new distributor for IRISYS. The IRISYS model 4010 is a mature thermal imaging camera, so while we are new as a distributor, the camera has bee used for home inspection for a fairly long time. IRISYS is a UK company so most customers have been in the UK and Europe; they are starting to penetrate USA markets for thermal imaging. The qulaity is quite good and very competitively priced.
We will sell the model 4010 for $3850 in low quantity; we discount more for qty 10 or more. The thermal array is 160 X 120, so very good image quality and temperature sensitivity and images can be stored on SD card. We are located in Northern California; we will run product demos in our area for now. We can rent units for people who want to try it for a few weeks. You can contact me at Les.Tack@pembrokeinstruments.com for more info including the powerpoint I mentioned. |
I may be looking at early year. |
Condo, and the couple unit owners I spoke with were blissfully ignorant of the system. Sure would loved to have seen a thermal pic. |
IRISYS is getting better known. The IRISYS model 4010 with 160 X 120 pixel format might sell for a lower price then most FLIR B-CAM's with lower resolution sensors. I have seen some comments here on the IRISYS model 1010 with 16 X 16 and that model is not appropriate for comprehensive home inspection. But the 4010 represents tremendous value vs. products from FLIR and Fluke.
These cameras are worth consideration especially if you are seeking the lowest price without any sacrifice in performance. For more details see http://pembrokeinstruments.com/prod-thermal-imaging.php. For a complete price list of our models please contact me at sales@pembrokeinstruments.com |
| Good info about multimeters and safety | badair | Electrical Inspections | 8 | 7/29/08 10:35 PM |
| Deere John: It's Been A Good Ride | jburkeson1 | Miscellaneous Discussion for Inspectors | 1 | 7/19/08 12:29 PM |
| OAHI Out Of Control - Bylaws Breached - Documented Proof | rwand1 | Canadian Inspectors | 423 | 2/25/08 6:20 PM |
| Grounding -V- Bonding Article (Good Read) | pdoane | Electrical Inspections | 0 | 10/12/06 4:31 PM |
