Old 5/26/09, 3:36 PM
mnicholet's Avatar
mnicholet mnicholet is offline
Please Note: mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default HVAC leakage
What do you think of these cool pictures The interior flooring covering was curled hardwood over top of these warm cavities.
ID:	28899   heating-venting-air-conditioning-leakage-ir_0204-medium-.jpg.jpg
Find an InterNACHI certified Washington Home Inspector (and anywhere else in North America)
Old 5/27/09, 12:08 AM
rbibler rbibler is offline
Please Note: rbibler is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: HVAC leakage
First floor or second floor ?
What is the Camera do you have ?
Best
Ron
Old 5/27/09, 12:40 AM
mnicholet's Avatar
Best
Ron
Second floor, Flir B-Cam SD
My focus doesnt look very good huh? Its hard to get my cam to take nice crisp pics. Maybe it needs repair!?!
Old 5/27/09, 4:50 PM
dbelmont dbelmont is offline
Send a message via Yahoo to dbelmont
Please Note: dbelmont is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi Mark,
You are right about the focus.
Do you mean thye wood flooring had actually curled over these places?
Old 5/27/09, 9:08 PM
Chuck Lambert Chuck Lambert is offline
Unmoderated Guest
Please Note: Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
Focus is easiest to do in Black/white and then switch palettes
Old 5/28/09, 11:28 AM
jallcroft jallcroft is offline
Just a thought - recessed lights (hot circles) warming up the joist bay (warmer bays).
Old 5/28/09, 2:03 PM
David A. Andersen's Avatar
Radiant floor heating through air duct leakage?
BPI# 5015804
Old 5/29/09, 12:35 PM
William J. Decker's Avatar
Plenum ducts?
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 5/31/09, 12:05 AM
mnicholet's Avatar
I mounted my B-cam on a tripod in a controlled environment. Took my time and focused as much as possible and slowyl squeezed the trigger. These are the pics I got. Do you think my camera is focusing properly? Is this about as much clarity I should expect out of a FLIR BCAM SD?
Thanks,
heating-venting-air-conditioning-leakage-ir_0207.jpg   heating-venting-air-conditioning-leakage-ir_0208.jpg   heating-venting-air-conditioning-leakage-ir_0209.jpg   heating-venting-air-conditioning-leakage-ir_0216.jpg
Old 5/31/09, 2:17 PM
Hey Mark I with you on trying to work with the lower end cameras. its hard. I think thats what every inspector looks at with these cameras what can i afford. and when we see images from a high end camera Man O Man i want one... they do help... I have been working with a 160X120 camera for 2 years now and its time for me to step up to the plate and get a better camera.
You will come to a point that you will need to step up.
Best
Ron
Old 5/31/09, 3:19 PM
Focusing tip: if you have trouble focusing your camera because of low temperature differential etc. Set your camera on manual. Hit the up arrow and increase your level setting until the warmest object is just barely visible. The smaller the object the better. In low differential conditions you may have to create a warm spot (put your hand on the wall or create a reflection of yourself by using your diffused foil temperature reflect device). You can then focus your camera until the object is the largest, clearest or has the highest temperature reading. The cameras now focused for that distance. Set your camera to automatic so you can see your composition, if you wish, and take the scan.
BPI# 5015804
Old 6/3/09, 1:57 AM
lmelso's Avatar
lmelso lmelso is offline
Please Note: lmelso is a non-member guest and is in no way affiliated with InterNACHI or its members.
Just passing through the message boards here, used to be a NACHI member, stopped doing inspections to focus more on IR. I came across the images provided of the warm cavities. I had an almost exact set of images from a couple years ago, it was from recessed lights below, so whoever guessed that one is prob. correct. By the way, manually adjusting the image can sharpen it up, but 120x120 isn't going to give the best resolution. Have the internal optics been cleaned and serviced? I had a early mod. BCAM (non-SD) and unless there was a good DeltaT, the image wasn't good, but that is true w/ even more $ cams. I noticed the BCAM SD and Infracam SD models have a slightly better image, they upgraded the sensitivity. Keep in mind, "better" cam = more expensive upkeep, repairs, and tend to have more complex elements that can fail.
3 days left for HVAC discount bgromicko Miscellaneous Discussion for Inspectors 0 3/28/09 11:36 AM
what to report on old hvac equipment bking Inspecting HVAC Systems 8 7/6/08 5:10 PM
Room size requirement for HVAC supply kweiss Inspecting HVAC Systems 3 6/9/07 7:58 PM
Access to Electrical Panel in Ontario by HVAC Contractors Nalliah Thayabharan Canadian Inspectors 8 5/21/07 4:01 PM
Condemned Furnaces Spark Safety Issues Gary Reecher Inspecting HVAC Systems 7 3/8/07 9:17 PM
