Old 8/7/11, 3:32 PM
Brandon Clark's Avatar
Brandon Clark Brandon Clark is offline
Default Help with FLUKE SmartView Please
This FLUKE software is driving me nuts. I take all my images in IS2 format so I can adjust them if needed.
What drives me crazy is having to go in an manually delete every one of the temp. markers on every single photo Is this necessary or is there a way around it?
I can click on the "edit all images" tab but it doesn't allow me to remove the markers from the images. It only allows me to change from normal to ultra contrast and adjust the pallet.
I've read the directions 25 times and I can't figure it out. Is it possible to capture in IS2 format and exclude the temp markers without opening every single image?
Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/7/11, 3:34 PM
David A. Andersen's Avatar
Default Re: Help with FLUKE SmartView Please
Don't use Fluke?!???
Sorry, I'd help if I could, "really"!
BPI# 5015804
Old 8/7/11, 3:49 PM
Charley L. Bottger's Avatar
Me also I would help but I don't do Fluke my guess is no you have to visit each image give Bill Warner a call he will help you and he does the Fluke thingy
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 8/7/11, 4:27 PM
Sean Fogarty's Avatar
Brandon
You could leave the center temp mark out when taking the images.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 8/7/11, 6:57 PM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
Here is your solution Brandon...
http://www.nacbi.com/software_and_documents
Old 8/7/11, 10:08 PM
Yeah that might be a bit of an overkill to get rid of my temp. markers but it's good to know I have options
So what's up with yall discriminating against my camera? I saw every camera listed but the Ti-32.
Is that about the going rate on universal software or is that a more advanced program. I may be obtaining another FLIR in the near future and one program would be really nice, that is if it gets rid of the temp markers..
Old 8/8/11, 6:00 PM
William Warner's Avatar
William Warner William Warner is offline
Simply turn your markers off on the imager settings itself for all images "captured". I leave them off 99% of the time and rarely include marker data in my reports. Unless you have competently adjusted for reflected ambient temps, target emissivity, and distance to target spot ratios, your marker data is generic at best and may be grossly inaccurate.
When you have turned the markers "off" in the imager settings, they will not show up when you load them into SmartView until you manually turn them back on with the software whether they be "all markers" or individual. When you first load them, SmartView simply regurgitates the exact saved image and settings at the time they were "captured" form your imager until you edit them.
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Fluke Smartview & Stuff dbowers Thermal Imaging, Infrared Cameras & Energy Audits 4 9/18/10 5:58 PM
Fluke Elec Tester Recall jbushart Electrical Inspections 1 3/11/10 11:07 PM
Fluke Ti32 / Fluke TiR32 & Level X Infrared Certification Package jkaylor Thermal Imaging, Infrared Cameras & Energy Audits 6 9/10/09 7:37 PM
Has Your Fluke Digital Meter Been Recalled? jbushart Electrical Inspections 1 5/16/09 9:21 AM
Fluke Smartview software question kweiss Thermal Imaging, Infrared Cameras & Energy Audits 2 4/22/09 9:30 AM
