Old 11/7/11, 8:09 PM
Brad Brinke Brad Brinke is offline
Default Hot!
What might cause this?
Inspecting Norfolk and Hampton Roads
www.procraftinspections.com
Energy Audits in Norfolk
www.procraftgreen.com
Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/7/11, 8:15 PM
Linas Dapkus's Avatar
Linas Dapkus Linas Dapkus is offline
Default Re: Hot!
Loose connection?
Old 11/7/11, 8:44 PM
Jeffrey R. Jonas's Avatar
Default Re: Hot!
Originally Posted by ldapkus1 View Post
Loose connection?
My thought also.
Old 11/7/11, 9:01 PM
William Warner's Avatar
William Warner William Warner is offline
Default Re: Hot!
So why aren't the bare conductors "hot"?
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Old 11/7/11, 10:04 PM
Default Re: Hot!
They're poor emitters and are reflecting the background.
Old 11/7/11, 10:40 PM
Sean Fogarty's Avatar
Default Re: Hot!
At the same color range?
You would think they would be different to some degree. The wire sheath and metal would reflect different.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 11/7/11, 10:42 PM
Default Re: Hot!
Whats the possibility of OX paste on the wire preventing the exposed alum from showing a heat reading?
865-256-5397
Old 11/7/11, 11:15 PM
Chuck Evans's Avatar
Default Re: Hot!
Attachment 49542
Probably a loose or high resistance connection at the terminal. It would be easier to determine without the fusion. Would like to see a plain IR image with more of the conductor showing. You will likely see rapid heat dissipation the further you move up the conductor away from the connection.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 11/7/11, 11:17 PM
Default Re: Hot!
My money says it is. But why doesn't it look like it is?
Houston, TX
Old 11/8/11, 3:49 PM
Charley L. Bottger's Avatar
Default Re: Hot!
My money is on a loose terminal and a time factor but just guessing I would think the amp load had just been increased and the wire itself had not had time to heat as much as the loose terminal connection and the outer insulation. Would be nice to know the amp draw and when it was applied was it a constant load or variable inquiring minds want to know
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 11/8/11, 4:55 PM
Default Re: Hot!
Yup...
Is the lug really that hot or are we seeing part of a reflection from some other heat source like an incandescent bulb above the panel or behind the inspector? What was the reflected background temp measurements?
Interesting thermal exception that sure leads to a lot of additional unanswered questions!
Give a man a fish, he eats for a day... teach a man to fish, he eats for a lifetime.
Old 11/8/11, 5:54 PM
Default Re: Hot!
Only if he can find a shovel to dig the worms!
Old 11/8/11, 6:07 PM
Default Re: Hot!
Well... true dat!
Old 11/8/11, 6:11 PM
Default Re: Hot!
Thanks for the responses fellas. I took several pictures at different angles and the temp never changed on the lug. The breaker for the water heater was in the 150 degree range as well. This was actually a re-inspection after it was "fixed" from about a month ago. You can see the other side is not warm at all. There was a small amount of OX paste on the wire. I sent this image to the electrician so he could see what I was looking at.
Old 11/8/11, 6:25 PM
Default Re: Hot!
Nothing takes the place of being on site all we can do is guess
NACHI Member
State License # 130
