If the conductor Delta-T is 900 degrees above ambient, do you think it's an issue?
I exaggerated, it was really only 870 above ambient. Captured video too. Had to terminate the inspection because I couldn't finish after turning off the power to the house. Corporate owned relo. Could have easily caused a fire if not found ![]() Video here http://www.youtube.com/watch?v=NHWQOgyRRrw . Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
| Find an InterNACHI certified Idaho Home Inspector (and anywhere else in North America) |
I don't know Chuck, don't over step your bounds.....you should probably pulls some breakers and confirm things....
Or from those that don't like IR like you and I, "I could have found that without IR." Nice find and pics. Better than me, I only found two moisture issues today Professional Inspector Level I Infrared www.AbsoluteInspections.net www.homeinspectorsplanotx.com www.homeinspectorsmckinney.com Absolute Inspections, LLC 972-463-0887 |
I like the crispy wires. What would cause a neutral to get so hot?
Fogarty Inspection Services Group of Knoxville TN Sean Fogarty Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.homeinspectionknoxville.com |
Causes loose connections. May produce 240 VAC at the connection... Good example to keep handy for your reports. But then everyone knows there isn't any voltage on white wires!!!??? Quote:
| Panel Surround / Exposed Wiring Question | thance | Electrical Inspections | 11 | 2/19/08 10:06 PM |
| Service Panel Started Fire | mashburn | Electrical Inspections | 14 | 3/30/07 11:12 AM |
| Electrical Inspection with Temp. Service? | dandersen | Electrical Inspections | 16 | 6/27/06 11:41 PM |
