Has anyone heard of Palmer Wahl Infrared heat spy 3000 and the Mikron 7800. Are they a good camera ?
thanks Tony Inch by Inch Inspections |
| Find an InterNACHI certified Wisconsin Home Inspector (and anywhere else in North America) |
Plus do these two look familiar? http://www.aikencolon.com/Ideal-61-8...ra_p_1831.html http://www.irisys.co.uk/thermal-imag...atasheets.aspx However the Mikron 7800 is super nice: 320x240 resolution, 60 mk thermal sensitivity, 60Hz refresh rate and a 500C temp range! Kind of strange you pick such different levels in cameras to compare. Only the FLIR B400 (add on the temp option) and the FLIR T400 can compete with that. The B400 and T400 have a little better thermal sensitivity at 50mk, and only 30Hz on the refresh. Unless the 7800 is drastically cheaper than 20K it would be tough to compete with the B and T 400's. If you want to go that high up the ladder check out one of these three. http://www.aikencolon.com/Electrophy...as_c_1119.html Those three are about as good as you get, with a 640x480 rez and very affordable compared to other cameras they compete with. Jason Kaylor – JJ VP of Specialty Products 877/207-1244 AC Tool Supply Fluke Thermal Imagers Irwin Industrial Tools Fluke Ti10 Thermal Imager Fluke TiR Resources Miller Fall Protection Retrotec Duct & Blower Door Last edited by jkaylor; 6/3/09 at 1:01 AM.. |
rbibler is a non-member guest and is in no way affiliated with InterNACHI or its members.
If they are older cameras stay a way from them. 10K will put into a very nice camera thesed days
Best Ron |
Jason Kaylor – JJ VP of Specialty Products 877/207-1244 AC Tool Supply Fluke Thermal Imagers Irwin Industrial Tools Fluke Ti10 Thermal Imager Fluke TiR Resources Miller Fall Protection Retrotec Duct & Blower Door |
Call www.InspectorOutlet.com No one can beat their prices. No one.
How about a ThermaCAM BX320 25ThermaCAM BX320 with 45° Lens$11950.00 http://www.tequipment.net/FlirBX320.html So im off by 2K But you can find used one for around 7K. Best Ron Last edited by rbibler; 6/7/09 at 3:05 AM.. |
I would advise against the Micron. I had one. Not very durable - the design of the flip up screen and hinge is a big weak point. The picture quality degraded significantly over one year. Developed a white "halo" around the picture that would not go away. The Micron people/engineers could not help. Not sure I believe that its specs are true compared to Flukes or FLIRs (both FLIR and Fluke reps that I talked to when shopping for the one I have now suggested that the Micron - manufactured in China - specs were inflated.)
Professional Inspector Level I Infrared www.AbsoluteInspections.net www.homeinspectorsplanotx.com www.homeinspectorsmckinney.com Absolute Inspections, LLC 972-463-0887 |
Jason Kaylor – JJ VP of Specialty Products 877/207-1244 AC Tool Supply Fluke Thermal Imagers Testo Infrared Cameras HotShot Hi-Rez Infrared Cameras Fluke TiR1 Resources FLIR B60 Resources Retrotec Duct & Blower Door |
For me I would have that BX320 Over any of the news cameras for that amount of money. This just the way I see it... A real work horse... Best Ron |
Not sure if I would consider resolution and thermal sensitivity as junk, that is the actual IR microbolometer detector that you are paying for. I am not sure if the BX320 has an optional telephoto lens, but if you ever get in to that type of work you will not be able to do long distance quantitative analysis without telephoto. It isn't so important that you have to have it off the bat, but it is great to be able to have the option. Another option on the newer B series the the ability to add on higher temperatures. It is a tad frustrating when you have a camera that goes to approx 100C, and you then get a call from someone wanting you to come out and do their plant or industrial setting full of gears, motors, etc. Spending around 10k, then not being able to do the job will drive ya nuts. With the newer B series you can simply add that feature on at a later point. David Anderson has a BX320, and he loves it. But I bet if you asked him if he had to pick today he would take a B200 or B250 over the BX320. The 200 is much cheaper and the 250 is about the same price. You are very correct about the BX320 and EX320, both are great cameras. At the time they were made, and even today, they are tough to beat for the price. I would suggest you get a demo on the BX and newer B series. What is on paper and actual field performance are two different things. Jason Kaylor – JJ VP of Specialty Products 877/207-1244 AC Tool Supply Fluke Thermal Imagers Testo Infrared Cameras HotShot Hi-Rez Infrared Cameras Fluke TiR1 Resources FLIR B60 Resources Retrotec Duct & Blower Door Last edited by jkaylor; 6/3/09 at 4:20 PM.. |
Hey Jason Good to chat with you about cameras. I like the new systems and all the stuff that they sport. But pound for pound My money is on the BX 320 And yes they have a telephoto lens.
I have work with the Flukes and the Flir cameras. Unless you want a T360 or T400 For the money the BX320 is a hands down work horse. I will say no more on this subject. Just my 2 cents Best Ron Last edited by rbibler; 6/3/09 at 10:05 PM.. |
Jason you may be right about where Mikrons come from. I was going on what a competitor rep said. But that aside, I stand by not buying one. My experience was bad, I had one for a year. Based on personal comparison with a TiR1, I believe that their specs are overblown, but have only my opinion based on my use. In the end it cost me a lot of money. If the OP ould like more details feel free to contact me directly.
thanks for all the info I will look into it.
Here is the link for Palmer wahl http://www.palmerwahl.com/pdfs/Heat%...%20HSI3000.pdf
| 1 Day Infrared Seminar- NYS CE Approved for Home Inspectors | bmerrell | Thermal Imaging, Infrared Cameras & Energy Audits | 0 | 1/11/09 6:44 PM |
| Free Online Snell Training Session: Buying an infrared camera | John Snell | Thermal Imaging, Infrared Cameras & Energy Audits | 4 | 12/17/08 8:40 PM |
| Infrared inspection | rcooke | Thermal Imaging, Infrared Cameras & Energy Audits | 5 | 4/12/08 1:42 PM |
| InterNACHI discount on infrared camera course in New York. | gromicko | Thermal Imaging, Infrared Cameras & Energy Audits | 3 | 3/10/08 9:05 AM |
| razir thermal FLIR infrared imaging camera for energy audit and home inspectors | Will H. Roberts | General Inspection Discussion | 4 | 4/16/07 12:13 AM |
