Old 3/13/09, 3:37 PM
kweiss's Avatar
kweiss kweiss is offline
Default Infrared Imaging instrumental in finding shower leak for Frisco Home Inspector
Yet another example of the power of infrared when properly used as part of a home inspection.
I was able to detect this shower leak in the closet behind the shower. The shower had been running for about 15 minutes when the first IR picture was taken. The warmer signature at the baseboard was the crucial indicator. Moisture was confirmed with a moisture meter as shown. The second and third IR pictures show the thermal signature that is created as the moisture cools and begins evaporating and seeping into the pad.
March has been a big shower leak month so far. That makes 5 in two weeks.
infrared-imaging-instrumental-finding-shower-leak-frisco-home-inspector-shower-leak-found-closet-3-.jpg.jpg
ID:	27401   infrared-imaging-instrumental-finding-shower-leak-frisco-home-inspector-shower-leak-found-closet.jpg   infrared-imaging-instrumental-finding-shower-leak-frisco-home-inspector-shower-leak-found-closet-1-.jpg.jpg
ID:	27403   infrared-imaging-instrumental-finding-shower-leak-frisco-home-inspector-shower-leak-found-closet-2-.jpg.jpg
Kevin Weiss
Professional Inspector
Level I Infrared
www.AbsoluteInspections.net
www.homeinspectorsplanotx.com
www.homeinspectorsmckinney.com
Absolute Inspections, LLC
972-463-0887
Old 3/13/09, 4:33 PM
Brian E. Kelly's Avatar
Default Re: Infrared Imaging instrumental in finding shower leak for Frisco Home Inspector
Would the moisture meter have detected the moisture without the IR picture?
Old 3/13/09, 7:01 PM
kweiss's Avatar
Yes, if you checked the right area.
Not all of the area along wall was wet. So if you simply spot checked and picked the wrong spot you would have missed it. It did not register to the surface testing mode of the meter. There was also a pile of toys in the closet that I had to move to check with the moisture meter, but the Infrared showed the suspicious area without moving them. How often would an inspector clear out personal belongings from a closet to probe? I guess some would, but many would not.
I often find that IR is just another valuable tool, giving initial indicators that something is wrong or showing the extent of the problem when only a small portion is visible.
I had two leaks last week that did not require IR to find - water was clearly visible on the floor of the bathroom, pouring outside of the foundation, and or pooling in the garage below. In those cases, IR simply helped to show the extent of the moisture around the areas you could see with your eyes.
I personally believe infrared is an invaluable tool. But ultimately, it is still a tool. Inspection protocol and experience is still more important.
Kevin Weiss
Level I Infrared
972-463-0887
Old 3/13/09, 7:09 PM
Michael Larson's Avatar
Agree. I'm not knocking IRT but the inspector should always pay close attention to areas adjacent to showers and tubs.
Pressing ones's knuickels into carpet of this area would likely have revealed the leak in this case. Confirm with a moisture meter if needed.
Michael Larson
Hudson, WI
Old 3/13/09, 7:27 PM
kweiss's Avatar
IR is much more sensitive than hands/skin. I have had many examples where the carpet was not wet to the touch and the moisture could not be felt. But Infrared sees the moisture in the pad below the carpet. This was one such case, believe me I try to get wet fingers to confirm things. There is something about having actual water on you finger to back up the tools that erases any possible doubt.
Kevin Weiss
Level I Infrared
972-463-0887
Old 3/14/09, 6:08 AM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
Michael,
Using IR is so much faster and better than using your knuckles or hand. It also gives the inspector and the client a visual image of the extent of the damage. See attached images
I did a scan on a 40 ft high ceiling recently (did not verify findings with moisture meter) that was approximately 5000sq ft in size in less than 20 minutes including documentation (photos).
This technology is invaluable to an inspector, and IMO inspectors that have realized the benefits of IR are way ahead of everyone else.
Images 3 and 4 high ceiling (1x1 ceiling tiles with 1 inch drywall below, commercial building)
Images 12 and 13 are from a home inspection (basement exterior wall)
Good find Kevin!!
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 3/14/09, 11:31 AM
Mario, I said I was not knocking IR.
I'm sure if and when I buy one I will fall in love with it too.
But it's not a must have tool.
Michael Larson
Hudson, WI
Old 3/14/09, 12:54 PM
Charley L. Bottger's Avatar
Neither is a screw driver or a flashlight but they sure are handy The sop states that if the crawl space is accessible you must enter it does not state that you have to take a flashlight with you
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 3/14/09, 12:58 PM
Let's not make this a war between the IR haves and have nots.
I'm sure your were all doing a good inspection before you fell in love with your IR cameras. At least I hope so.
Michael Larson
Hudson, WI
Old 3/14/09, 1:35 PM
Don't be so sure I thought I was doing a good inspection before the camera but after I bought mine it scared the crap out of me
NACHI Member
State License # 130
Old 3/14/09, 3:26 PM
Andrew MacDonald's Avatar
Andrew MacDonald Andrew MacDonald is offline
What Charley said! This morning found a leaking shower pan in upstairs bath by scanning the downstairs family room ceiling. No visible staining or peeling paint. There is NO DOUBT I would have not found that anomaly without IR. Simple as that. My client just received a superior addition to his inspection which he gladly paid for.
Andrew MacDonald
MacDonaldPropertyInspections.com
InsightThermalDiagnostics.com
ITC/FLIR Certified Building Science Thermographer
ITC/FLIR Certified Level 1 Thermographer
Old 3/14/09, 7:14 PM
kweiss's Avatar
Michael,
I know you are not trying to start a war. I think the point we are trying to make is that we keep finding things with IR that you would not with other tools - period. I do not believe I would have found the shower leak in the original pictures - touching the carpet did not indicate a problem.
Today's inspection had two roof leaks. They were not making any kind of stain. I definitely would not have found them without IR.
Like Charley said, I thought I did a pretty thorough job at inspection before using IR. After using it for two years, I shudder to think about what I did not see, could not see. I did the best I could at the time, but now I can do even better and I like that.
Have a good week guys, I'm off to go skiing with the family for the week.
infrared-imaging-instrumental-finding-shower-leak-frisco-home-inspector-roof-leak.jpg   infrared-imaging-instrumental-finding-shower-leak-frisco-home-inspector-roof-leak-1-.jpg.jpg
Kevin Weiss
Level I Infrared
972-463-0887
Old 3/14/09, 9:38 PM
I know you are not knocking IR Michael, I'm just pointing out how fast and accurate this technology is! I guess we will have to agree to disagree on whether this tool is a must have for proper building diagnostics.
Tel.# 416-722-6132
Old 3/16/09, 12:25 AM
That is what I thought.
Old 3/21/09, 11:03 AM
I recently did a Home inspection on a house that was bank owned. The house was winterized, meaning the water was off. I asked my clients to make sure the water was turned on when I did the inspection, the bank agreed and had the water turned on one day prior to the inspection.
It turns out there was a plumbing leak from the 3rd floor washroom as evidenced from a simple IR scan on the 2nd floor ceiling directly below the 3rd floor washroom. There was no visible evidence to suggest that there was an active plumbing leak in the immediate area. I’m quite sure that if the water remains on for an extended period of time it will be visible.
I would not have known of this plumbing issue if the area was not scanned using an IR camera.
Tel.# 416-722-6132
Orange County Home Inspections whandley California Inspectors 12 5/18/11 6:35 AM
Bungalows to Mansions Professional Home Inspection, LLC bgraham Miscellaneous Discussion for Inspectors 7 1/11/09 3:03 PM
