Old 6/21/08, 5:57 PM
Banned
Default Infrared inspection for electrical problems
Just read another members website promoting IR here's what it says:
From these temperature variances I can report probable issues with things like: insulation, water infiltration, air infiltration, electrical problems, the presence of vermin, and more
How are persons claiming residential electrical problem inspections without loading all breakers/fuses, wiring, junctions, switches, receptacles, motors, etc to do a full electrical inspection?
I find this misleading as it is a mere fluke to find anything without some to full current draw on all circuits and devices.
Old 6/21/08, 6:09 PM
John McKenna's Avatar
John McKenna John McKenna is offline
Default Re: Infrared inspection for electrical problems
How do you know if he did it wrong?
Executive Director - Master Inspector Certification Board
25 Yrs Constr Exp - 13 Yrs Home Inspector Exp
American Home Inspection - East Texas.
Old 6/21/08, 6:41 PM
Not a fluke....here are two examples:
The first image is a 15 amp fuse that was overloaded. It measured at 13 amps.
The second image is a dimer switch that measured between 127 and 130 degrees F (at face plate). Dimers are usually hotter than a normal switch due to internal resistance, but this particular dimer controlled 8 can lights. All from this one dimer switch.
Rather be safe and call out both issues than be sorry
Kevin
infrared-inspection-electrical-problems-electrical1.jpg   infrared-inspection-electrical-problems-electrical2.jpg
Kevin A. Richardson
Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493
301-942-4610
www.richnspect.com
www.infrared-diagnostics.com
www.thehomegreenteam.com
Old 6/21/08, 6:56 PM
Chuck Lambert Chuck Lambert is offline
Unmoderated Guest
Please Note: Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have more of a problem with this statement than any other.
Old 6/21/08, 7:08 PM
William Warner's Avatar
William Warner William Warner is offline
Why?
Rodent burrows in ceiling insulation show up quite nicely!
Rodents and other mammals produce heat and show up quite nicely as well!
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Old 6/21/08, 7:44 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Why...I came across this a few weeks ago. 2 squirrels in an interior wall cavity, and yes I was the one to remove them.
See it here
Old 6/21/08, 9:09 PM
David A. Andersen's Avatar
Brian, evaluating electrical circuits with infrared should be loaded to 30% minimum for evaluation.
For the most part turning on all the lights in the house and after running appliances (stoves, ovens, microwave, dishwasher, refrigerator, HVAC, water heater (the electric) generally gets most circuits up to that capacity. That's less than 5 amps on a 15 amp circuit.
It doesn't take very much to find an electrical issue with the infrared camera. The important thing is to evaluate the temperature in comparison to the amperage draw on the circuit at the time of testing. Even at a low load, defective devices show up warm.
If you have a circuit breaker at 90° at a 70° ambient panel temperature and you only have 6 amps on a 15 amp breaker, I think it's safe to say there are issues to investigate further.
Old 6/21/08, 9:54 PM
Unmoderated Guest
Originally Posted by wwarner
Why?
I guess I see more electrical problems than squirrel problems. Fortunately in Southern California there are not that many squirrels, now rats are a different story!
Old 6/21/08, 10:15 PM
Where did Brain go?
Old 6/21/08, 10:25 PM
Kevin
I love your images. Very nice camera.
Old 6/22/08, 12:15 AM
Dominic J. Maricic's Avatar
Dominic J. Maricic Dominic J. Maricic is offline
Send a message via ICQ to dmaricic Send a message via AIM to dmaricic Send a message via MSN to dmaricic Send a message via Yahoo to dmaricic
Move up to Arrowhead Lived up there for 10 years. Plenty of Squirrel problems! Like them always eating the food from my bird feeders, or running INTO the house and up my leg!
Brian,
That's an awesome IR photo. Amazing that they had nested in INTERIOR walls!
2008 InterNACHI Member and Innovator of the Year
HOME INSPECTOR PRO HOME INSPECTION SOFTWARE
NOW ONLY $499 ($15O OFF!!)
Easy to use, customizable Home Inspector Software that runs on Windows, Mac & Linux
InterNACHI members receive 3 months of FREE home inspector website hosting
List yourself in our Home Inspector Directory Free
Watch our NACHI.TV Software & Search Engine Optimization videos!
Help@HomeInspectorPro.com
Old 6/22/08, 10:08 AM
William R. DeVries, CMHI's Avatar
William R. DeVries, CMHI William R. DeVries, CMHI is offline
During the inspection all lights would normally be turned on to test ? Yes
I leave them on and continue inspecting
last inspection is electric panel and branch circuts after visual I then pop out the Bcam and have a lookise, if i see any anomolies then I go room to room and scan areas, if I see something out of ordinary I refer to electrical contractor for futher eval and include IR photo A call to my electrician friend and he can in most cases be right there in a few hours. Sellers do not mind buyers do not mind and issues are or can be resolved that day.
Now I have not run into vermin as of yet but did find a ceiling not insulated due to squirrels, but they were dead in the attic, damage was already done
ASNT Certified Level II Thermographer
Certified Mold Inspector (Pro-Lab)
Certified Mold Inspector IAC2
Certified Home Inspector INACHI 07040201
Commercial Property Inspection
Certified Master Home Inspector
2008 InterNACHI member of the year
Magnum Property Inspection
Inspect it before you buy it
613 561 5327 office
613 929 9919 mobile
We use and recommend
Home Inspector Pro Software
HomeGauge Software
Old 6/22/08, 9:48 PM
Banned
Are we talking about electrical circuits and devices throughout the house or just the service entrance / panels and circuit overload protection?
In the far extremes of a circuit, if you had a bad connection that produced a resistance of say 10 Ohms, here's the way it may play:
With a .5 amp draw, the heat generated would be 2.5 Watts (P= I squared x R). At the point far away from the panel, would you be able to pick up that heat. If the current increased to 1 amp, the heat would be 10 Watts. If it increased to 8 amps by other lights and receptacles on the circuit being used, the heat would now be 640 Watts........enough to cause a glowing connection and a fire!!!
http://glowingconnection.com/
http://www.springerlink.com/content/lwh56537056v515u/
http://adsabs.harvard.edu/abs/1976STIN...7719352M
I would think that to properly say an IR electrical inspection was done all receptacles should be individually loaded and scanned. If there was a nicked wire in a wall or box, it may not heat up until a large enough amperage load was running through it.
Have to careful on creating expectations!!!
Old 6/22/08, 10:00 PM
Banned
Kevin:
How do you figure a fuse designed to blow at 15 amps was overloaded at 13 amps? Yes, the intent of code for regular house circuits is to design them so as to not draw more than 80% of wire rating hence a #14 AWG wire should not carry more than 12 amps- a 20% safety factor, theoretically!!
Kevin
127 -130 degrees F is the delivery air temp of most forced warm air furnaces. The blowers usually come on at 150 degrees and safety "off" is 200 degrees F. Was this temp of just 30 degrees above body temp really a problem?
Old 6/23/08, 1:20 PM
Kevin:
You asked a question, then in the same paragraph, provided the answer. A circuit that is above 80% of rating will always get written up for further evaluation by a Licenced Electrician. If an Electrician comes behind me and certifies the circuit to be fine, then so beit! I sleep better at night knowing I did my job.
This is an odd statement. Your comparing apples to oranges. Execessive heat in "electrical" components = potential trouble. period.
By most standards, yes. At the very least it warrants further evaluation!! And, the reference is from "ambient temp" NOT "body temp."
Kevin
Kevin A. Richardson
301-942-4610
www.richnspect.com
Infrared inspection rcooke Thermal Imaging, Infrared Cameras & Energy Audits 5 4/12/08 1:42 PM
New Infrared Training Event - Making Money with Infrared sramos Thermal Imaging, Infrared Cameras & Energy Audits 1 4/12/08 12:16 AM
Flir offers FREE infrared conferences dplummer Thermal Imaging, Infrared Cameras & Energy Audits 5 3/16/08 12:48 PM
Preventing Moisture related Problems mcyr Ancillary Inspection Services & Additional Topics 1 12/19/07 9:30 AM
Tidbits from the ASHI Message Board jbushart Miscellaneous Discussion for Inspectors 124 4/27/07 12:05 PM
