Old 12/29/07, 11:48 AM
David P. Valley's Avatar
Default Infrared Sample reports
I'm in the process of designing my personal Infrared report for my clients and it's coming along pretty good. I like it so far and I'll post it when it's finalized.
I took some ideas from the BS manual that was giving to me last month by Scott Wood. He gave all the students permission to copy portions of his report, if they needed ideas for designing an IR report.
Just curious....Can you all post some samples of your reports for everyone to get additional ideas for their reports?
Old 12/30/07, 1:37 PM
Default Re: Infrared Sample reports
For home inspection or "add-on" surveys, I use Home Gauge....it works just fine for inserting thermal images next to a digital image.
I created three seperate sections for each survey. Your welcome to use what you like or if you have suggestions on improvement, I would love to here about it:
ITI ELECTRICAL SURVEY
13.0 ELECTRICAL METER ENCLOSURE (Report signs of abnormal temperature differences or overheating)
Comments:
13.1 MAIN ELECTRICAL PANELS, DISTRIBUTION PANELS, AND SUB-PANELS (Report signs of abnormal temperature differences or overheating)
Comments:
13.2 MAIN OVERCURRENT DEVICE AND ENCLOSURE (Report signs of abnormal temperature differences or overheating)
Comments:
13.3 CONNECTED DEVICES AND FIXTURES (Report signs of abnormal temperature differences or overheating)
Comments:
ITI MOISTURE SURVEY
14.0 FOUNDATIONS, BASEMENTS AND CRAWLSPACES (Report signs of active moisture or excessive condensation)
Comments:
14.1 CEILINGS (Report signs of active moisture or excessive condensation)
Comments:
14.2 WALLS (Report signs of active moisture or excessive condensation)
Comments:
14.3 FLOORS (Report signs of active moisture or excessive condensation)
Comments:
14.4 ROOF STRUCTURE (Report signs of active moisture or excessive condensation)
Comments:
ITI ENERGY SURVEY
15.0 CEILINGS (Report signs of missing, non-uniformly distributed, marginal, or wet thermal insulation)
Comments:
15.1 WALLS (Report signs of missing, non-uniformly distributed, marginal, or wet thermal insulation)
Comments:
15.2 FLOORS (Report signs of missing, non-uniformly distributed, marginal, or wet thermal insulation)
Comments:
15.3 DOORS (Report signs of air leakage or infiltration)
Comments:
15.4 WINDOWS (Report signs of air leakage or infiltration)
Comments:
15.5 DISTRIBUTION SYSTEMS (Report signs of heating and cooling losses or leaks from distribution systems)
Comments:
See attachment for example.
Kevin
Kevin A. Richardson
Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493
301-942-4610
www.richnspect.com
www.infrared-diagnostics.com
www.thehomegreenteam.com
Old 12/31/07, 6:17 AM
Kevin
Kevin,
I appreciate your input, I do like your reporting style, but I refuse to go out and purchase HG in order to design an IR report.
If others would chime in and tell me or show me what they use, the information would be greatly appreciated. I tried Microsoft Word as Scott Wood (from ITA) suggested and I can't get the text to line up properly (tight) with the images.
Until then, I'll keep hacking away at my formats until I come up with a bigger and better idea.
Right now, I'm thinking of purchasing Duel-View software. The designers of PALM-TECH and PDSPECT made this software. I downloaded their FREE version and I'm playing with it now. It's OK.
Old 12/31/07, 7:30 AM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
David
When I purchased my camera it also came with "Quick Report" a software for IR reports. This software (I was told) is worth $1200.
http://www.flir.ca/support/infrared_...re_updates.asp
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 12/31/07, 7:55 AM
ldapkus ldapkus is offline
I also use Home Guage. It's easy to modify an existing home inspection template or download a blank template and start from scratch. I found Quick Report useless and can't see paying thousands of bucks for the additional software that FLIR offers.
Old 12/31/07, 8:15 AM
Originally Posted by mkyriacou
David
Yes Mario. I downloaded that particular software also (it was FREE) and I find it very confusing compared to Duel-View software. And it is no way worth 1,200.00 in my eyes. Please don't get "Quick Report" confused with the $7,000.00 REPORTER 8.0 software that Flir is offering. This software is megabucks and is absolutely not worth it (IMHO).
I'm will be ordering Duel view in the next couple days. Unless of course, someone has something better.
Old 12/31/07, 8:21 AM
Roy D. Cooke, Sr's Avatar
I think this company gives NACHI a good discount (25%) if not they should as they could get one pile of business if it is any good .
We have seen a big interest in IR and if many find it is well worth having .
This fall could see more going with it .
Flir should also get on the band wagon and give some free courses for Home Inspection or a lot more reasonably to those who buy their camera
...Cookie
Old 12/31/07, 8:45 AM
Marcel Gratton's Avatar
David,
In Word, "Tools", "Options", "Edit", choose "square" from Insert/paste pictures drop down menu.
Or from word: choose "Insert", "Picture", "From File" and it will position the pic at cursor; you can right click on the pic and "Format Picture" or choose other opitions.
On The Level Inspection
Gatineau, Québec
Old 12/31/07, 8:56 AM
I just down loaded their free thirty day trial about 30 seconds at high speed another minute to install. Will keep all posted .
...Cookie
This is what I told them on their order box ( bad spelling and all)
Yes I live in Ontario and you do not have Ontario in your list
You also do not have NACHI in your list .
NACHI is the largest Home isnpection association in the World .
A lot of us are now getting IR Cameras and just many might be interested in your soft ware .
we have had a discusion on our BB .
Why not visit and talk to us NACHI.org/forum
Thanks Cookie
Old 12/31/07, 9:14 AM
Barry Adair's Avatar
...Cookie
Thanks Cookie
Now I know who to blame for all the vendor spam in my mailbox
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 12/31/07, 9:57 AM
Sorry If you get any thing from Me you can be sure I signed it .
Usually person mail is Roy some times roy
....Cookie
Old 12/31/07, 10:25 AM
Charley L. Bottger's Avatar
The software Dominic has out HIP has a great image loader that allows sideXsides at the click of a button and is template specific. I am going to build a template just for my IR when I get my standard inspection template customized. Will also build one just for Commercial and one for mold testing. I am finally coming out of the dark ages. HIP has a very user friendly document editor that I can copy and paste word doc's from past inspections right into what I am working on at the time. I'm luv'n it.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 12/31/07, 11:03 AM
John McKenna's Avatar
John McKenna John McKenna is offline
I use WORD all the time to put two photos side by side.
Reduce photos to desired size and copy and paste.
Thats it.
Executive Director - Master Inspector Certification Board
25 Yrs Constr Exp - 13 Yrs Home Inspector Exp
American Home Inspection - East Texas.
Old 12/31/07, 11:28 AM
David
I use HomeGauge like Kevin and I didn't get confused with Reporter 8.0. The cost for the training alone is $350 and half day course.
Tel.# 416-722-6132
Old 12/31/07, 1:48 PM
Kevin,
Hey David,
I agree that you don't have to purchase HG to create a nice looking IR report. A simple word document works just fine, but it's just a matter of formatting the images and word-wrapping the text. However, doing a report in Word takes far too long unless you have spent a good amount of time setting everything up to work as you need it. Word is a very powerful program.
I also like Dual-View and have played around with the demo. I have not purchased it because HG works for every service I offer. It's that flexable!!
I think your original question was to give report samples, so that is what I gave you. Use what you want
Are you looking for a reporting software that will enable you to do both standard inspection reports as well as IR reports? Or are you just looking for IR reporting software?
You might also want to check out HomeInspectorPro, as another member posted before me. I've played with the demo and it works well with inserting IR images.
Good Luck.
Kevin
Kevin A. Richardson
301-942-4610
www.richnspect.com
Need help selecting report software mmonroe Inspection Hardware, Software & Publications 207 9/25/10 9:34 AM
Infrared imaging...in all our futures? lfreeze Plumbing Inspections 1 6/18/07 11:38 AM
Infrared and acoustic imaging...our future? lfreeze Miscellaneous Discussion for Inspectors 7 6/17/07 7:00 PM
